88 350 tpi formula, no tps signal, backfires, rich
Old Dec 10, 2011 | 02:25 PM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
Transmission: 700-r4
Axle/Gears: 3:42 auburn
i got the car a week ago, stock everything, checked for codes, data, everything shows good, even closed loop, but there is no reading from the tps, MAF readings are in the 36000 range, changed both sensors with new ones, still pops backfires when past 2000rpms, has new plugs,wires,correct timing at 6' with est unhooked, car is nice but its driving me nuts! all everything is plugged in except emission junk, getting a code for tps, maf voltage and est, wth?!?!
Old Dec 10, 2011 | 02:29 PM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
Re: 88 350 tpi formula, no tps signal, backfires, rich
oh yeah, running hogrich and sounds like its got a nice cam, til you reset the ecm, and it idles between 1200/1500
Old Dec 10, 2011 | 04:18 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You may have a bad ecm. Check your car for bad grounds first. There should be a major ground point behind your passenger side head with one of the wires looking like a shoe lace.
Old Dec 10, 2011 | 04:19 PM
ninetyone's Avatar
Axle/Gears: 3:42
You will continue to get code 42(EST) unless you unhook your neg. battery cable for a few minutes to reset the ecm.
Old Dec 10, 2011 | 05:13 PM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
changed computers already, checks all body, chassis,engine grounds, injectors all ohm at 17
Old Dec 10, 2011 | 05:42 PM
ninetyone's Avatar
Axle/Gears: 3:42
Unplug the Maf and start it up. See if it runs better.
Old Dec 10, 2011 | 05:50 PM
ninetyone's Avatar
Axle/Gears: 3:42
If you have a new tps with the same problem, then I would try running new wires from the ecm to the tps. http://www.chevytalk.org/fusionbb/sh...hp?tid/241136/ Check out that wiring diagram.
Old Dec 10, 2011 | 11:15 PM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
maf unplugged makes no difference, im checkin out those schematics now thanks nintyone
Old Dec 11, 2011 | 09:49 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
You said the original MAF was reading 36,000, and you replaced it. What readings are you getting with the new MAF. They should read 3,000 at idle and about 9,000 at 3000 rpm under no load.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
