Black smoke 1991 305 TPI
Old Mar 31, 2012 | 08:04 PM
osci's Avatar
I have a 1991 Trans Am 305 TPI. Starts great, runs good, seems to hesitate at about 50 miles/hr. Check engine light comes on, black smoke out the exhuast. Try to read codes by hooking A & B pins together, check engine light just flashes, no codes. New injectors, No vacum leak, EGR seems to be working. Any suggetions would be appreciated.
Old Mar 31, 2012 | 08:14 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Black smoke 1991 305 TPI
cts, tps or bad ecm
Old Mar 31, 2012 | 08:38 PM
osci's Avatar
Thanks for the reply. what is cts or tps I'm just learning
Old Apr 1, 2012 | 12:13 AM
Engine: Lb9
Transmission: M20
coolant temperature sensor, or throttle position sensor
Old Apr 1, 2012 | 08:20 AM
osci's Avatar
Thanks for the reply, I have already replaced the coolant temp. sensor. I will try replacing the tps before replace ecm. Thanks again
Old Apr 5, 2012 | 01:19 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Before you spend alot of money on parts, you may want to connect a scan tool and monitor data to see what's actually happening. Tunedperformance is correct that it may be one of those components. There are also several other possibilities, such as a wiring or power supply/grounding issue that no number of new parts will ever fix. And diagnosis by elimination gets expensive real fast.
Old Oct 22, 2017 | 02:02 AM
faisal's Avatar
Have the same issue with running rich fuel ....
Old Oct 22, 2017 | 10:08 AM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Didn't even noticed you bumped an old thread, was going to help the OP haha.
Check out the map sensor stuff, that usually causes rich/Rough idle symptoms when something is wrong.
Old Oct 22, 2017 | 10:19 AM
faisal's Avatar
hhhhh .. just noticed ... damn 2012 !!!!!!!
I need to ask this too dose bad injectors cause also the same fuel rich issue ? I'm in the other side of planet earth -middle east- trying to fix this bird with pair hands No repair shops here know how to deal with TPI cars >>
jaridjohn
Jul 8, 2024 03:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
drathaar907
Aug 6, 2015 04:20 PM
