MAF Sensor Location
Old May 18, 2012 | 04:26 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
MAF Sensor Location
My car is running very rich so I went to look for my MAF and oxygen sensors to see if they are bad. I found the oxygen sensor fine but the MAF (mass air flow sensor) seems to be missing. They are normally between the air filter and the throttle body but nope. All I have is the air filter, a hard tubing which goes to a flexible tube and than into the throttle body. Am I missing something or do I just not have one? Thanks
Old May 18, 2012 | 04:55 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: MAF Sensor Location
I think 1991 had Speed Density instead of MAF.
Old May 18, 2012 | 05:00 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Yours is a Speed Density system which uses a MAP sensor. Yours has no MAF sensor.
Old May 18, 2012 | 05:57 PM
lstreich1961's Avatar
Car: 1992 1le z03 1992 b4c camaros
Engine: 305 tpi 350 auto
check that your engine temp sensor is not out of range.Also be sure the vacuum hose is connected and is good going to the map sensor and the map is plugged in
Old May 18, 2012 | 10:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Have you pulled the engine codes to see if anything is showing?
the easiest way to pin point engine control problems
Old May 18, 2012 | 10:19 PM
Just to make sure the MAP is mass air pressure right?
Old May 19, 2012 | 08:16 AM
And yes the engine codes told me there was a random misfire but not sure where that puts me...
Old May 19, 2012 | 07:08 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What code # ?
Old May 19, 2012 | 08:51 PM
I have no idea, that's what Goodyear told me since I have no code reader. I don't like trusting them but I have no other method of retrieving codes.
So if my MAP sensor is bad how would one go about testing it to see if it is bad or not?
Old May 19, 2012 | 09:08 PM
Car: GTA
You need nothing more than a paper clip or other piece of wire to read codes on a 3rd gen.
http://www.austinthirdgen.org/index.php?pid=27
Old May 19, 2012 | 09:35 PM
O wow, did not know that. Thanks a lot man! Thats awesome!
Old May 19, 2012 | 10:01 PM
Car: GTA
Or just got to Autozone, or any parts store, and they can use their "key" to do it for you. Just play dumb that your Check Engine Light is on & they'll do it for you. Autozone gave me one of their keys years ago.
Old May 20, 2012 | 12:37 PM
Well I did that and the only code that came up was code 12 which from my understanding just means that the diagnostic system works. My engine light will come on while driving here and there but most of the time it will turn back off after a couple minutes. So, I'm kinda confused...
Also how do i check that my engine temp sensor is not out of range?
Old Mar 16, 2021 | 02:42 AM
Nbachorn's Avatar
Hey I know it’s been a decade but if you’re still around what was the fix to your issues of running rich and the engine light coming on here and there?Im having identical problems and trying to figure it out and stumbled on this thread.
IROCKET4U
Feb 7, 2009 01:01 AM
scarello
Aug 17, 2007 01:05 PM
A Seven X
Jan 15, 2006 09:59 PM
A Seven X
Jan 15, 2006 09:24 PM
eatmydust
Mar 13, 2004 07:11 PM
