Identifying my ECM.
Old Jun 18, 2012 | 09:12 PM
shitgoboom21's Avatar
Car: 1987 Camaro IROC-Z
Engine: TPI 305
Identifying my ECM.
I am trying to purchase a new ECM and the parts store says they have two options for my car. How do I find out which one is the one I need? Thanks.
Old Jun 18, 2012 | 09:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Identifying my ECM.
Originally Posted by shitgoboom21
. How do I find out which one is the one I need? .
Give us a little CLUE
What year car do you have ?
What engine do you have?
What intake system do you have??????
Fill in your profile on the left maybe
Old Jun 18, 2012 | 09:47 PM
Engine: TPI 305
Oh damn. I can't believe I forgot that stuff. Its an 87 TPI 305 Camaro.
Old Jun 18, 2012 | 11:14 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Has a '165 ECM
GM service # 1227165
Replacement versions may be numbered 16198259 or 16198445
Same ECM version used for all '86- '89 TPI cars ; F-Body or Vette , 305 or 350ci
And I would be buying a used ECM ; always available in for sale dept under $50
https://www.thirdgen.org/forums/engi...d-87-iroc.html
Old Jun 21, 2012 | 11:17 AM
WillieL's Avatar
Hi really need help - i have a 89 iroc z28, 5.7L 350 standard that runs lousy bought last fall - winter stored, now has chunky idol right from start up - changed fuel filter, spark plugs and wires and reconditioned msf, had garage run scan and still showing bad code for msf was told could be overridden with a speed density chip ?? or cracked wire is there any way I can tell what will fix it without spending another small fortune?
Old Jun 21, 2012 | 06:45 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by WillieL
still showing bad code for msf w or cracked wire
More testing needed .Takes more than just replacing the MAF unit
Read
http://www.chevythunder.com/maf_code_33.htm
http://www.chevythunder.com/maf_code_34.htm
was told could be overridden with a speed density chip ?? ?
Not without changing the computer
Will get better response if you start a new question about your engine problem
Old Jun 21, 2012 | 07:03 PM
WillieL's Avatar
will try these tips and let you know thanks
Old Jun 23, 2012 | 10:48 PM
Engine: TPI 305
Thanks and sorry I left out the info. I was kinda in a hurry.
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
angel2794
Sep 8, 2015 06:22 PM
