Any downside to a 58MM Throttle Body
Old Jan 15, 2013 | 03:11 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Might be able to get a free or very cheap Professional Products 58mm Throttle Body. My motor definetly dont need that but is there any downside in slapping it on?
Old Jan 15, 2013 | 03:37 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Any downside to a 58MM Throttle Body
There might be if you don't open up the plenum entrance to match it. It could cause turbulence on the flat portions stick out into the airflow which would cause it to act smaller. Otherwise I have not seen any problems.
Old Jan 16, 2013 | 09:46 AM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
58mm is too big and not necessary for a stock motor. Think about it, when you crack open the throttle, your now getting more air in with the same movement. This is going to cause the throttle to be much more senstive.
Your engine will also only be able to suck in only what air it needs. The stock TB is fine on stock cubes up to I want to say, 350hp.
Putting a 58mm TB on a 305 or 350 is pointless, will only cause worsened drivability, and is generally only necessary on a well built 383.
Old Jan 16, 2013 | 09:51 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Pointless powerwise but but won't hurt anything if the plenum is ported to match.
On the bottom is my T-body I built back in 93ish. Its a stocker that I bored 2 52mm then milled the center out of. been on the car for 20yrs from a stock motor all the way 2 my 400 stroker. No problems at all.
The top one is a 58mm that I have given the TTOPspeedshop treatment to.
Old Jan 16, 2013 | 11:29 AM
Guest
Guest
Posts: n/a
Yes their is a downside. A waste of money.
Old Jan 17, 2013 | 11:45 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
It will not hurt anything but you will probably not notice any performance gain unless you do other mods.
Old Jan 17, 2013 | 11:48 PM
TTOP350's Avatar
Unless its free.
Old Jan 18, 2013 | 01:05 AM
Guest
Guest
Posts: n/a
Originally Posted by TTOP350
Unless its free.
still not worth it...
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Thornburg
Aug 27, 2015 08:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
