very low fuel pressure at fuel rail
Old Mar 1, 2013 | 06:04 PM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
Hey everyone I broke down today and bought a fuel pressure tester and when I hooked it up (ignition on engine off) I got 15PSI and then it immediately dropped off. Alldata says it's sapose to be between 40.5 and 47.0 and the instructions are the tool said it should hold pressure until you push the button to release it. Anyways so I get what it's telling me I was just wondering where to start digging because the pump does pump for about 2 seconds and shuts off, but doesn't build enough or hold pressure so would that be meaning the regulator is faulty or is and automatically timed cuircut on start up? I know when cranking I can hear the pump, and after a while it'll sputter than if I give it a little gas it'll start and idle fairly high close to 1500-2000 rpm in park, which might that be a sign of a leaky injector? I had recently changed the fuel filter under the car is there one in the tank? I also inspected the rubber lines just outside the tank and them seemed solid (no craking or leaking) and no other noticeable leaks. or could it just be the pump is broke and allowing back flow of fuel? I am just look for someone with experience and telling me where to start. Thanks for your time.
Old Mar 1, 2013 | 06:31 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: very low fuel pressure at fuel rail
Fuel pressure check is performed this way: Locate the schrader valve. Place a small towel around the area to catch any fuel as you attach the tool. I usually take off my gas cap first before i attach the gauge. Ok, so attach the gauge ,put the gas cap back on, Next disconnect the fuel pressure regulator vacuum hose from the intake manifold and plug it, also plug the other end at the manifold. Now start the car and check the fuel pressure. It should be at 43.5 psi (stock specs for a 350 tpi).
Old Mar 1, 2013 | 06:33 PM
ninetyone's Avatar
Axle/Gears: 3:42
Do you smell gasoline around the car anywhere? That is a sure sign of a leak
Old Mar 1, 2013 | 06:36 PM
nuggie's Avatar
nope no gas smell even checked at the front where it connects to the fuel rail no signs of leakage
Old Mar 1, 2013 | 06:38 PM
ninetyone's Avatar
Axle/Gears: 3:42
ohm all of your injectors
Old Mar 1, 2013 | 06:41 PM
nuggie's Avatar
I did the ohm check on them last spring I'll do it agian but will that show a leaking one?
Old Mar 1, 2013 | 06:44 PM
ninetyone's Avatar
Axle/Gears: 3:42
I think you need to pull your plugs to really tell what is going on for that.
Old Mar 1, 2013 | 06:46 PM
ninetyone's Avatar
Axle/Gears: 3:42
https://www.thirdgen.org/forums/tpi/...rops-when.html
this could be helpful to read
Old Mar 1, 2013 | 08:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If as you say the pump is running then the rails should have pressure unless the FPR is allowing the pressure to bleed off back to the tank.
Can check the FPR by temporarily clamping the return line from the rail and see if the pressure rises with the pump running ; if it does the FPR is faulty.
If it doesn't then the injectors could be leaking but the cylinders should be full of fuel ( pull a plug ) and be running rich out the exhaust
There is also the known problem of the fuel line inside the tank from the pump leaking , bleeding off line pressure
Old Mar 2, 2013 | 02:18 AM
nuggie's Avatar
okay I took the fuel pump out and came to find that the 1.5 inch hose connecting to the pump to the rest of the tube dealios was split. after buying a whole foot cuse they can't just sell me the length I needed, I found that the pump with the engine off key on got me 20 PSI and held. Then I got the car to start (fairly quickly ) and found that I got 43PSI (fallowing the method that ninethyone described above. I will give her a test drive tomorrow and retest the engine off key on might have just been plenty of air in the line from it being disconnected. Thanks for the help yall!!
Old Mar 2, 2013 | 11:04 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If your pump was old, you maybe should have changed it while you were there. (filter changed?)
I hope they sold you submersible fuel line and not just high PSI fuel line.
Old Mar 2, 2013 | 11:16 AM
nuggie's Avatar
probably not it was just the stander I kept asking for high pressure and he seemed confused on that. He kept saying fuel hose is fuel hose. It wasn't too hard to get as long as what they sold me will work for awhile
Old Mar 2, 2013 | 11:59 AM
TTOP350's Avatar
Fuel hose isn't fuel hose! there is high/low psi and submersible and non submersible.
If you put non submersible in the fuel tank it will swell up and blow out fairly quicky.
Bring your wallet cuz its pricey.
http://www.napabeltshose.com/fuel-de...ible-hose.aspx
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
