help choosing a cam
Car: 88 GTA "Cocaine"
Engine: 350 tpi
help choosing a cam
I was wondering if I could use the lt4 hotcam in my tpi setup. I know that the stock tpi heads are good to 480 lift and the cam is 492 lift. what can I do to the heads to make them work.
will the cam work with my computer with a custom tune on the e prom. the cam says that it is not computer compatable
Re: help choosing a cam
You have to change the valvetrain to accomodate higher lift. That being said, the .492 lift is with 1.5 rockers. I'd want a little more lift, a little less duration, BUT......it would work, mechanically speaking. And yes, with a tune, it would run fine, and sound pretty good.
....however, that cam with either 1.5 rockers OR the intended 1.6 rockers is too much for stock heads and stock TPI, even if a tune has it running properly.
Engine: 350 tpi
that is some bad sobering news because I found a lt4 cam for like $150.
is this a cam that would work better
http://www.summitracing.com/parts/lu...make/chevrolet
that cam is like twice as much but if it will work then its worth it
I ordered 22lb injectors but now I am thinking that it would have been better to go with 24lbs injectors and from southbay they are only around 5 bucks more what do you think
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Just my opinion, but i would save for and invest in new heads, then get the cam to match your set up. That's better than throwing a few hundred here and there, then wanting better heads later. Then you can get bigger injectors and a custom tune. Just my
Engine: 350 tpi
yeah but I am using the stock tpi and if I put better heads on it it will need a better intake and then I am getting into all kinds of money.
I am gonna stick with the stock heads.
what kind of springs should I get to match the cam if I buy it
I ran a zz4 cam with a stock tune ('89 MAF) with stock heads/LT4 spring, and stock TPI and loved it. enough cam for a seat of the pants difference, AND enough lope to just not quite sound stock. Cams are relatively cheap because guys opt for a slightly bigger cam when they buy zz4 crate motors. ....I ended up going with a custom tune, but it DID run very well on the stock tune. Ever so slightly within the parameters of the stock chip.
...however, I did have full headers/exhaust at the time. You'll want this too, in fact, I'd do this first.
Engine: 350 tpi
yeah I am definatly gonna get some headers and a y pipe that is in the budget.
I just found out that the previous owner put a 305 tpi set up in my gta and I am not happy. I have a roller 350 block that I was gonna save for another project but it looks like the gta is gonna used up my reserves of 350's.
I am gonna use the 305 heads and have 1.94 valves cut in. so with a bunch of porting work I will have a good flowing high compression motor.
I was thinking of going with a zz4 cam but I cant find one for sale right now. you know where i can find one
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
