Using a FAST ecm to control TPI
Old Aug 25, 2013 | 04:02 PM
BOD1979's Avatar
Car: 1989 CONVERTABLE IROC
Engine: 383 TPI
Anybody swap out the stock ecm for a fast system. My motor is highly modified and wouldn't run on the stock ecm
Old Aug 25, 2013 | 07:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Using a FAST ecm to control TPI
How "highly" modified? (there is only so much you can do to a 383 while running a TPI intake )
Who was doing the tuning ?
Plenty of radical engines on here being run by reprogrammed stock ECM's
F.A.S.T uses the same ECM inputs ( sensors) as the stock system ; is just much more user friendly in terms of tuning
Old Aug 25, 2013 | 07:32 PM
BOD1979's Avatar
Engine: 383 TPI
It's a 383 running 10.5 to 1 compression. Edelbrock heads, TPI manifold and runners. the plenum has been ported to match the runners and throttle body. 58mm throttle body and 30lb injectors. Comp cam roller 549 int/ 544 exh with a duration of 242/248.
First I had TPIS burn me a new chip twice. Then I put a Holley commander 950 in it brought it to 2 different tuners after spending over $1000 on tuning and the car still not running right I am putting in a FAST self tuning system. I talked the guys at FAST and they said the self tuning would work
Old Aug 26, 2013 | 11:54 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Question needs to asked , way would you run a cam with that sort of duration on a TPI intake that can't make use of it.
What LSA is the cam ?
Of course they would , they are trying to sell you something. Assume you are talking about FAST EZ EFI ?
http://www.fuelairspark.com/fas/mult...-efir-kit.html
You are aware it only does fuel control , you lose electronic control of the spark that you have with the stock ECM programming
https://www.thirdgen.org/forums/post...910-post6.html
https://www.thirdgen.org/forums/dfi-...i-install.html
https://www.thirdgen.org/forums/dfi-...stock-ecm.html
https://www.thirdgen.org/forums/dfi-...-about-ez.html
https://www.thirdgen.org/forums/afte...lley-fast.html
Old Aug 27, 2013 | 03:58 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Well I tuned a friends 383 running 10.6:1, AFR heads, HSR Intake, 58mm TB and a 240/248 110lobe cam with a 730ECM and 8D code. Running open loop and belive it or not it pass emission test here in sweden! (running a diffrent tune of cause) here is the second testdrive we made with the new engine
what was the problem with the tunes you tested?
Old Aug 27, 2013 | 03:03 PM
BOD1979's Avatar
Engine: 383 TPI
[quote=vetteoz;5626287]
https://www.thirdgen.org/forums/dfi-...i-install.html[/quo
No not that system this one http://www.fuelairspark.com/fas/ez-e...-ignition.html
It controls everything. Timing control, fans, fuel pump even bumps up the idle when you turn on the AC. The only thing it doesn't do is the lockup. I got a TCI unit to control that http://www.tciauto.com/tc/200-4r-700...iring-kit.html
Old Aug 27, 2013 | 03:20 PM
BOD1979's Avatar
Engine: 383 TPI
Not running a stock intake. I have an edebrock intake and runners.
This is the cam COMP cams recomended
Old Aug 27, 2013 | 03:24 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Nice mild build, go with a Holley HP efi and never look back
Old Aug 27, 2013 | 09:16 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I'm not the best engine expert, but I too have to wonder why so much duration on that cam. Even with an aftermarket setup it's still a long tube runner design and has it's limitations.
What exactly is the problem? Idling? Driveability (part throttle, full throttle)?
Old Aug 28, 2013 | 12:45 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I cant help to notice he did not say the duration was measured at .050" as what we normally compare with. That would mean its a very small cam. If I am wrong then I agree that cam is ridiculously too big for your combo and am not surprised any EFI system is having trouble running it smooth. Even my 236/248 cam I felt was too much for my boosted 383 and I was running 10.9's
With a cam that size I would recommend nothing less then a Alpha-N tune unless you have a real expert working on it.
Fast355
Dec 2, 2016 06:33 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
