305 TPI 5speed manual! time too shift between gears
Old Oct 17, 2013 | 09:03 PM
xendr7wk's Avatar
Car: 91 z28
Transmission: 5 speed
I think that there is something wrong with my camaro :/!I dont think it should be like that, but you never know.. I need opinions from people..
How fast do you have too go to shift two second,third,fourth, and fifth gear, like saying your racing with friends just for fun.. I always have too shift from first-second like around 15/20mph..second-third 30mph... Third-fourth at 40...fourth-fifth around 50/60.. cuz if I dont shift at that certain speed, the rpms will go all the way to the red numbers like at 60rmps... I don't think its supposed to be like that..
The car is all stock!!
Old Oct 17, 2013 | 10:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 305 TPI 5speed manual! time too shift between gears
https://www.thirdgen.org/forums/post...488-post2.html
Old Oct 17, 2013 | 11:07 PM
xendr7wk's Avatar
Car: 91 z28
Well Yeah, but i have seen some vídeos on youtube, Like a V6 camaro in there, it looks like it goes faster than mine,... so you saying nothing is wrong... But what about this, last time I race with my friend , he has a V6 S10 stock... I couldnt even go a car in front of him..
Old Oct 17, 2013 | 11:33 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Who knows , too many variables.
How many miles on your engine , how good is the tune?
Maybe he is a better driver?
Maybe he has a NOS button under the dash ................
Old Oct 18, 2013 | 08:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Tach is broken:
https://www.thirdgen.org/forums/elec...meter-fix.html
RBob.
Old Oct 18, 2013 | 09:31 AM
xendr7wk's Avatar
Car: 91 z28
His truck is completely stock, and my camaro has 83*** miles on the motor, it was only one owner... I'm the second owner of the car, and is completely stock too....
Old Oct 18, 2013 | 10:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Originally Posted by RBob
This.
Drive the car by feel instead of by watching the tach. Hold each gear until it stops accelerating, then shift. After you do that for a while, you'll get a feel for when you're outside of the TPI's powerband, and you'll learn to shift just a little earlier.
Old Oct 18, 2013 | 11:57 AM
erik69&85's Avatar
You also have to consider the rear end ratio.... same rpm, different rear end will mean different speeds....
I have the same engine/tranny combo and I would say your shift points are about where I shift....I also find the car is a little slow than my 85z with a T5 since that car had a 3.23 rear end and it rev'd up faster.....
Old Oct 19, 2013 | 03:23 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
+1 to this. I did my motor swap in January and swapped to the 90's dash, running by the tach was useless. I ended up installing a mini tach on my a pillar and even after doing the tach fix I was under shifting like crazy, I was running off sound rather than pull, I didn't want to beat on my new motor too badly even well after the break in period was said and done. I don't trust factory instruments too well any more. Jim is right just feel it out, I suggest doing it alone for a while first. I can get up to around 40 in first gear before needing to shift with my t5
Old Oct 20, 2013 | 09:17 AM
xendr7wk's Avatar
Car: 91 z28
Thanks for everyone, thats what I'm going to try to do, feel the car, but in case I don't notice any difference, what should it be the the speed to switch between 1-2? Around 30-40mph?
Old Oct 20, 2013 | 12:15 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
You guys are going about it all wrong. Its a TPI Stock car. Your max HP is at 48-4900rpms. Thats where you shift at. 5000 is the max. Don't go by speed. Think people think!
Old Oct 21, 2013 | 12:05 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
His tach is wrong.....
Old Oct 21, 2013 | 12:38 PM
xendr7wk's Avatar
Car: 91 z28
the tach is not working how is supposed to work....
Old Oct 21, 2013 | 06:11 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I have a craazy idea maybe you can just feel for it! I don't think anyone has suggested that one right? I'm a genius lol just give it a go and see how it works out for you
Old Oct 21, 2013 | 06:26 PM
APACHE JOHN's Avatar
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
Oh geez I would have thought you couldn't figure that out.......I would have never posted....well you know it,s so easy....
Old Oct 21, 2013 | 06:28 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
So why are you posting now? He had a concern and posted in the appropriate section to get the answer he needed. That's why this forum is here.
Old Oct 23, 2013 | 09:06 AM
xendr7wk's Avatar
Car: 91 z28
If I had knew that the tach was wrong, I wouldn't had never posted anything...but I didn't knew what was wrong!!
Old Oct 23, 2013 | 09:11 AM
xendr7wk's Avatar
Car: 91 z28
Apache john... you post stuff like if you knew everything about anything! You probably don't even know how much, is two + two, divided by two lol.... Hope you know the answer, and If you get ir right, you are going to be the smartest person that knows everything !!! Lol...
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
