Cannot stop pinging. Need ideas
Old Aug 12, 2014 | 06:10 PM
Casey Meyers's Avatar
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
383 tpi had been running nicely for a while. The lifters got noisy after sitting during the winter. When replacing them, i port matched and cleaned up the lower manifold. After getting it back together, it now pings over 3000 and 1/3 throttle. I replaced the knock sensor and esc. Checked continuity from knock sensor plug to esc and is good. I ordered another chip and made no difference. Base timing is at 6*. 10:1 compression and 92 octane. The old lifters had been stuck at full height. I was thinking a burned valve but theres no unusual running. I swapped to a step colder plug with no change. It does run warm, which it always has. It sounds mostly towards the passenger side.
Old Aug 12, 2014 | 09:32 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Cannot stop pinging. Need ideas
Is there a possibility that the water passage from the front of the pass side head to the intake was partially blocked when the lifters were changed?
Old Aug 13, 2014 | 06:50 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
as a quick test , you could run some 100 octane racing fuel in it .if the ping goes away, you are on the right track. you might also use a can of seafoam to de carbon things a bit.
Old Aug 13, 2014 | 08:07 AM
Car: 86 Z28
Engine: 385 HSR
Im fairly sure the intake is clear. I will try the sea foam because the plugs did have some carbon on them. I want to try higher octane but i cant find any place nearby that sells it. I did verify the timing changed when revved but cant read the decal anymore to see where it is maxing out. Im saving up to switch to a holley avenger but i dont want to swap it and still have the same issue
Old Aug 13, 2014 | 08:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Whats the timing in the chip??
Old Aug 13, 2014 | 08:44 AM
Joe Tag's Avatar
A list of ethanol free stations in Pa. some up to 110 octane.
http://pure-gas.org/index.jsp?stateprov=PA
Old Aug 13, 2014 | 10:23 AM
Car: 86 IROC
Engine: 5.0 TPI
holley tuning tool= BFH !!
Old Aug 13, 2014 | 04:53 PM
Car: 86 Z28
Engine: 385 HSR
Ill ask the tuner what my max timing is at. Im going to try sea foaming it and see how it goes
Old Aug 13, 2014 | 04:56 PM
Car: 86 Z28
Engine: 385 HSR
The closest place in the gas listing that displays higher than 93 is 100 miles away
Old Aug 13, 2014 | 05:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Try setting base to 0 deg and see if it goes away
Old Aug 13, 2014 | 08:16 PM
Car: 86 Z28
Engine: 385 HSR
Ill see if that helps. I idles much better with 12* base but i would never run it at that
Old Sep 26, 2014 | 10:32 AM
Car: 86 Z28
Engine: 385 HSR
i tried sea foaming the engine. needless to say, it is now being rebuilt this winter
Old Sep 26, 2014 | 12:00 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Why?
Old Sep 26, 2014 | 02:55 PM
Car: 86 Z28
Engine: 385 HSR
ping got very bad and now has excessive blowby. i lost a half a quart of oil through the dipstick tube on a 20 mile drive. it also blows the pcv out of the valve cover if run hard and smokes out of the breather even with the pcv installed
Old Sep 26, 2014 | 05:02 PM
Car: 86 IROC
Engine: 5.0 TPI
time for a rebuild, my friend.
Old Mar 7, 2015 | 01:22 PM
Car: 86 Z28
Engine: 385 HSR
got it all apart. all ring lands were cracked and the crank had also cracked. ditched the tpi and went with a holley avenger
Old Mar 9, 2015 | 01:36 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
At least you discovered what the problem was. Good luck on the build.
Old Mar 9, 2015 | 02:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Tune is everything, mail orders usually don't work
toones
Jan 6, 2016 06:00 PM
Wade787b
Sep 29, 2015 01:15 PM
Stauf
Brakes
Sep 1, 2015 06:15 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
