L98 5 speed before and after bolt ons
Old 03-29-2015, 10:55 PM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
car is an 87 formula with a crate L98. Stock except for an ORX
Second vid is after a CAI, 1.7'RR's, and 2210 hooker super comps. (Open headers at this point. I also pinched off the fuel return line to temporarily raise the fuel pressure. TPI system is stock otherwise.
According to my GPS (live 5 hours from a track) it's gained around 9 mph from those mods.
Stock was a best of 91.8 mph
CAI alone got it up to 95.3 mph. The car felt noticeably faster from that alone.
After was the RR's, which got me up to 97.1 in worse conditions. Car revved higher.
Last was the 2210 hookers. Which were a fun install. I also pinched off the fuel return line to bump the fuel pressure. Car felt way faster again, and revved even higher. First pass was 100 mph on the nose.
Next up is an HSR. We will see what that brings! Thought I would share my experience so far testing individual mods.
Old 03-30-2015, 01:57 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: L98 5 speed before and after bolt ons
sbd-
Old 03-30-2015, 01:06 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Heres mine with a stock L98 G92 T5.
Old 03-30-2015, 01:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Hsr was big gain on my L98. .4 sec and 3 mph on average.
Old 03-30-2015, 11:25 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
https://www.youtube.com/watch?v=XvqS14L5uVs
That's sweet. My car is a G92 car as well
Old 03-30-2015, 11:26 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Damn. That's huge! These L98's are sure choked out
Old 04-02-2015, 09:36 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Old 04-02-2015, 09:39 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Ported and ready to go
Old 04-03-2015, 12:55 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Don't buy a Chinese HSR
Old 04-03-2015, 09:54 AM
LegacyThirdGen's Avatar
Car: 1987 IROC-Z
Engine: 355TPI
Transmission: TCI SF 700r4
Axle/Gears: Borg-Warner 3.27
Why? Pretty sure we've already established they're made well, they can be ported bigger, and they do the job just fine. If one of the performance industry's biggest name can't compete, well, that's their fault.
Old 04-03-2015, 07:02 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
The port alignment was horrid for one thing. And I had to do a pile of grinding just to get it to seat on the heads. Also the injector spacing is off and you can just barely pound the rails in place. Metal quality is good. But the casting is way off.
Old 04-13-2015, 10:05 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Update:
Finally got it running right with a debacle over some bad injectors. It ran 102 mph with ease in much warmer weather. AFR was in around that 12.5 range
Car runs great, even on the stock prom. It may have lost some low end TQ but it still has plenty and more than makes up for it on the high end. I shift it around 5800 now on the stock cam.
Old 04-13-2015, 10:44 PM
VincentZ28's Avatar
Update:
If you were to shift it around 4800-5000 you would go faster. Your power peaks around 4800.
Old 04-14-2015, 07:12 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
No it screams past 5000.
Old 04-14-2015, 07:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I shifted at 5500 on my hsr l98. Peak was 5200 but fallin quick by 5400. But it was leaning out alot. Tune was alittle off up top
I dont have the one in rpm anymore
Old 04-14-2015, 09:09 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
I have 1.7RR's too. Helps power over the curve
Old 04-14-2015, 09:54 AM
VincentZ28's Avatar
It may rev that high but you're not making anymore power that high. Especially with a stock TPI. Next time try it and see.
Old 04-14-2015, 09:56 AM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
I don't have a TPI. I have an HSR.
Old 04-14-2015, 01:40 PM
VincentZ28's Avatar
Ok.
Old 04-14-2015, 08:00 PM
VincentZ28's Avatar
My car went 13.20's@105 with just an exhaust system with 3.42 gears shifting at 4900 just like in my video above..
Old 04-14-2015, 09:40 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Before and after vids of racing the same hemi ram are up in the street racing section
lt500r55
09-01-2021 01:30 PM
355tpipickup
08-19-2015 10:02 PM
355tpipickup
08-13-2015 07:35 AM
jpearcy1
Wheels and Tires
08-09-2015 10:20 AM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: L98 5 speed before and after bolt ons
