Idle Issues
Old May 16, 2019 | 10:03 PM
jamesv's Avatar
Car: 1987 Chevrolet IROC-Z Camaro
Engine: LB9 > L98 5.7-liter V-8 TPI
Transmission: MD8 4-Speed Automatic MX0
Axle/Gears: GU5 3.23 G92
Idle Issues
I have a 1987 Camaro, 5.0 TPI/Automatic and am having some idle issues.
1. Without driving the car, the engine idles between 1,200 and 1,500 RPM hot or cold, it doesn’t matter.
2. I have adjusted the throttle position sensor to the appropriate ohms
3. I’ve backed the idle adjustment screw off all the way; it doesn’t touch the throttle plate.
4. The exhaust has a weird burnt odor.
Once I drive the car, the engine idle will:
1. Randomly drop to a normal operating RPM of approximately 700 RPM. (Which doesn’t make any sense to me because the idle adjustment screw now has no bearing on the idle, and I’m guessing the engine should probably die.)
2. When the car is in gear, it idles below 500RPM, and sometimes it acts like it wants to die.
3. While driving, as I start to apply breaks, I can see the idle drop almost to 0 RPM then it jumps back up to around 500 RPM. If it doesn’t recover from the near 0 RPM, the engine will die. (I did notice that when it does this, the brake pedal is not as stiff and will depress almost to its maximum)
I accessed the ALDL (Assembly Line Diagnostic Link) connector and jumped terminals A and B and received trouble Code 15.
15 Engine coolant temp sensor error (low temp indicated)
After changing out the sensor, I again jumped terminals A and B and now received trouble Codes 33 and 34.
33 MAP sensor circuit error (signal high indicating low vacuum)
34 MAP sensor circuit error (signal low indicating high vacuum)
I disconnected the Mass Airflow Sensor while the engine was running, and nothing changed.
How can you have high and low vacuum in unison, and how can I check to see if the Mass Airflow Sensor is defective?
This has me boggled and I want to get this fixed. Any help is appreciated.
James
Old May 16, 2019 | 10:18 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Idle Issues
Jamesv, one quick question. You have a 87 TPI. You mention about the MAP sensor. 87 TPI should have a Mass Air Flow Sensor, not a MAP sensor. Did you change your car to speed density?
Old May 16, 2019 | 10:27 PM
jamesv's Avatar
Re: Idle Issues
No Sir, its all stock. That's just the error code I'm getting from the ECM. Not sure what it means; the car has a mass airflow sensor.
Old May 17, 2019 | 03:09 AM
ikeepitreelz's Avatar
Car: 1988 gta-
Engine: 383 tpi
Transmission: 700 r-4
Re: Idle Issues
I was thinking maybe take a snap shot of the engine bay for us? Try doing the IAC relearn procedure. I had a friend with a camaro and he had idle issues and they were resolved with this procedure. I cleaned out the IAC port and the valve on the tip had some carbon and i lightly wet sanded the tip and it cleaned out good. follow everything here its pretty easy and i agree with the original poste to the article that most idle issues are traced to IAC problems or misadjustments. here is the link. Post back if this works for you so any future searchers can get an anwer.
https://www.thirdgen.org/forums/tech...ml#post1304610
Old May 17, 2019 | 05:06 PM
jamesv's Avatar
Re: Idle Issues
Thanks guys... I'll try this and get back with you on the outcome!
Old May 17, 2019 | 10:38 PM
jamesv's Avatar
Re: Idle Issues
Old May 20, 2019 | 10:44 AM
jamesv's Avatar
Re: Idle Issues
Well i went a head and replaced the Idle air control sensor, inserted a clip in the ALDL, 'A' and 'B' sockets and followed the directions with the exception of the EST bypass. I have no clue what EST is or where it is! I then started the car and it wouldn't run, it would die immediately. I then began to gas it to keep it running and suddenly it ran on its own, but just like it was before, high idle and the check engine light continued to stay illuminated. I checked the code again and got a 34. All together I've replaced the Temperature Cooling sensor and now the Idle air control sensor, and still no normal idle. Any other advice?
Thank you,
James
Old May 20, 2019 | 11:58 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Re: Idle Issues
You are looking at the wrong list of codes. That is for the later models with MAP/Speed Density. You have a MAF and that is high and low volume flow.
This would be a big indicator to me. While it can run without it... you should notice a difference
You can't, getting those codes together should tell you something. Yes, I think you have a problem with the MAF... but there is a lot of digging to do to solve it.
James
Could be relays (Cheap)
Could be a Fuse (Cheap)
Could be wiring
Could be the MAF itself. (Not Cheap)
I don't have it handy, but there is a FSM flow chart on troubleshooting the MAF circuit. I know tuned Performance has posted it multiple times on these threads. Try searching around for Code 34 or Code 36. Should come up in one of those threads.
Always start by fixing the codes.
Old May 20, 2019 | 01:12 PM
jamesv's Avatar
Re: Idle Issues
Thanks Kyle
Old May 21, 2019 | 08:43 AM
RKeats's Avatar
Engine: 5L TPI
Transmission: WCT5
Re: Idle Issues
Following along to this one. I have an 89' 350 TPI and it's doing basically the same thing. I had a code 33 and 36, and after changing the MAF, TPS, IAC, and both MAF relays, I'm now code free but the idle is still a bit weird. Stumped
Old May 21, 2019 | 04:30 PM
Car: 1988 gta-
Engine: 383 tpi
Re: Idle Issues
That same car that had the issue with idling problems also had at the same time a vacuum leak by the egr solenoid runner. This after the owner changed all the plenum gaskets and base manifold gaskets, I think he did not torque it at all from i suspect. The idle issue went away but the vacuum leak makes the engine run rough. I used throttle body spray to find the leak. Try doing the IAC relearn procedure step by step and disconnecting the est wire by the back of the firewall when doing the relearn. Also adjust the tps to, if i remember correctly .55v.
Old May 22, 2019 | 08:50 AM
RKeats's Avatar
Engine: 5L TPI
Transmission: WCT5
Re: Idle Issues
Do you disconnect that wire for the whole re-learn process, or only at a certain step? Also my idle is kind of junk, but any acceleration is perfect and responsive
Old May 26, 2019 | 11:00 AM
jamesv's Avatar
Re: Idle Issues
I am proud to report that the idle issue has been resolved! A third-gen buddy of mine found that a hard plastic vacuum line that runs along the right side of the plenum, and then under the throttle body was disconnected from a "T" fitting. Connected it and BOOM, no more codes!
I still have other posts out there with other issues, thank you all for the help
James
Old Jun 1, 2019 | 04:06 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
Re: Idle Issues
James
Which vacuum line is that? Can you post a picture?
Old Jun 15, 2019 | 05:14 PM
jamesv's Avatar
Re: Idle Issues
Left side of throttle body
From photo of left side of throttle body to vapor canister
Hard plastic line runs from intake manifold to under runners, to under throttle body and to vapor canister.
Old Jun 15, 2019 | 05:20 PM
jamesv's Avatar
Re: Idle Issues
Vin there are vacuum lines that run underneath the throttle body that intersect there in a “T”. The “T” is held in place (suspended) under the throttle body by the vacuum lines. It was difficult for me to see that the line was disconnected.
Kitten Tooth
Dec 31, 2016 04:27 PM
crazynights
Aftermarket Product Review
Oct 16, 2012 08:53 AM
Stevo
Jun 5, 2008 09:49 PM
