Fuel line fitting stripped help?!
Old Sep 2, 2021 | 01:03 PM
Swinnen25's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L L98
Transmission: 700R4 automatic transmission
Axle/Gears: 7.625 GM 10 bolt, 3.42 gears
I’m working on my 1991 Camaro z28 with 5.7L L98 TPI. I stripped one of the fittings for the fuel line between the fuel rail and the rubber hoses on the front of the motor. I’ll link pictures. I’ve gone everywhere even the dealership and nobody has anything that would replace it. Anyone have any ideas on how to fix? This is the only thing keeping my Camaro from running at the moment.
thank you
Old Sep 2, 2021 | 04:44 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Fuel line fitting stripped help?!
There were thousands upon thousands built, place a Wanted Ad here in TGO for the lines and possibly the rails if the female side of that fitting is stripped too.
I may even have a set, but I can't currently confirm that.
Old Sep 2, 2021 | 05:49 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
You could try taking a pick and reforming the threads by hand. Or carefully cut out the damaged threads.
Beyond that, you're looking at either making a new line, or buying a good used replacement.
edit: also leave the bracket loose while installing so the lines can move freely as they need to.
edit2: those don't look like fresh viton seals to me.
Old Sep 2, 2021 | 06:34 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
That looks very fixable with a small hacksaw blade to clean up the threads. Almost all the thread is still good, just clean up the rough portion with thin blade. The sealing comes from that rubbery viton o-ring seal, not the threads. Just need enough thread to hold light pressure on that o-ring.
Old Sep 3, 2021 | 10:03 AM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
+ 1 to looking fixable, use a thread die!
Old Sep 3, 2021 | 06:47 PM
Vader's Avatar
...Or a thread file.
Old Sep 4, 2021 | 09:10 PM
NoEmissions84TA's Avatar
I know, but how many people know what a thread file is?
Have you ever seen them for taper pipe threads?
Old Sep 4, 2021 | 09:22 PM
They DO exist for taper pipe threads.
But even better...….. ROTARY.
Old Sep 5, 2021 | 08:31 AM
Vader's Avatar
That looks a lot like something that can make a mess in record time. I hope no one believes the advertising - It's not for "any thread" since not all threads are 60°.
Old Sep 5, 2021 | 07:00 PM
Like any tool, it can work IF you know how to use it.
OTOH, you can screw things up equally as fast.
Old Sep 6, 2021 | 10:01 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you need hardlines lmk I have a set. I might have a 14,16mm thread chaser to fix the rail and have rails if needed. But like mentioned I’d use a thread file first
Old Sep 11, 2021 | 12:44 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
AFAIK, for the OP's specific application, these aren't taper threads.
Kfactor239
Sep 5, 2021 07:33 PM
illuminati
May 15, 2018 07:56 AM
Bob88GTA
Sep 11, 2017 04:54 PM
Ghettobird52
Nov 19, 2016 12:59 AM
ar1424
Fabrication
Aug 17, 2008 03:42 PM
