please help me choose a throttle body, 52mm or 58mm?
Old Jan 18, 2002 | 12:19 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I will have a 406 roller motor
with 10 to 1 comp.
226/236 540/ 560 lift 112LSA
forged pistons with a 125-150 shot of NO2
Edelbrock RPM heads
and a Superram with 30 lb. injectors
and a totally custom ship its a MAP set-up
I don't know if this matters but I have a T-56 with 3.73's
thanks for the help
Old Jan 18, 2002 | 01:13 AM
JR4444's Avatar
Defenatly 58mm. If you can find a bigger one go for that.
Old Jan 18, 2002 | 01:20 AM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
58mm, no doubt.
Old Jan 18, 2002 | 09:27 AM
Gta-Paladin's Avatar
AS&M Monoblade
Old Jan 18, 2002 | 11:28 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
WOW I was expecting to hear that the 58 is way to big or something like that. Thanks for clearing that up. I especially like the comment about if I could find one bigger go for that! LOL!
The monblade was a good one too! Can you link me to the page that has the monoblade? I would like to see it
Old Jan 18, 2002 | 11:36 AM
If you can find a link to arizona speed and marine they've got the monoblade in their inventory.
Old Jan 18, 2002 | 01:20 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Try www.azspeed-marine.com
With 406cu inches, I would definately go with the 58mm TB.
I'm thinking about a 395 stroker, with that stroker I will buy a 58mm TB.
Old Jan 18, 2002 | 03:42 PM
JR4444's Avatar
even on my engine the 58 isn't overkill.
Old Jan 19, 2002 | 02:31 AM
Torqomeo's Avatar
Hey i'm building similar motor!! Anyrate where is this mono-blade i looked at AS&M and i can't find it on there site. A mono-blade would be usefull even though im using the factory Plenum
Old Jan 19, 2002 | 03:35 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I couldn't find it at first either. You got to click on new products and look under there. Its pricey though $550
Old Jan 19, 2002 | 04:19 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
58 for that engine definetly.
Old Jan 19, 2002 | 09:44 AM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Curious, if a 406 requires a 58mm TB, why does GM sell the 502 RAMJET with a stock 48MM, and it makes 500+ HP. You'd figure for the cost of that crate engine, if a 52 or 58mm produced more HP, GM would have sourced it from one of the aftermarket suppliers.
Would it make sense to say the larger displacement can draw more air through the same TB? Granted on a flow bench, the 58 will flow more than a 48, but when you put a larger vacum source behind the TB, the flow rate changes as does the velocity, correct? I believe the flow bench uses xxx CFM at yy inches of mercury, right? If the mercury reading changes, so would the flow.
Comments?
Mark.
Old Jan 19, 2002 | 10:31 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
For a good price on TBs, go to Summit Racing (www.SummitRacing.com) or Excessive Motorsports.
Summit Racing carries Edelbrock, BBK, and Holley TBs 52mm and 58mm. But I think that Excessive Motorsports has a slightly lower price on the Edelbrock TBs.
Hope this helps,
Doc
Old Jan 19, 2002 | 12:53 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
is that webiste excessivemotorsports.com? I was thinking about the monoblade maybe if I save up for it
Old Jan 22, 2002 | 08:31 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Please do us all a favor and run the 48mm and then switch to a bigger one. If that 502 doesn't need one (58mm), you don't.
Old Jan 22, 2002 | 09:33 AM
Administrator
It would probably make more power with the 58mm TB. Probably at higher RPM.
Old Jan 22, 2002 | 03:39 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I found that mono blade. It's under new products.
http://www.azspeed.com/newitems-8.html
They recommend you do not use it on a small block!
Attached Thumbnails please help me choose a throttle body, 52mm or 58mm?-8.jpg
Old Jan 22, 2002 | 09:59 PM
Iroc n roll's Avatar
Correct me if I'm wrong but I believe TPIS also offers a monoblade TB. They advertise it flowing 1300CFM. Of course it could just be them stealing the AS&M one and raising the price, they enjoy doing that sometimes.
Old Jan 22, 2002 | 10:02 PM
BTW.... Mark_ZZ3 made an excellent point. TB ratings never consider the changing vacuum of the engine. Maybe these monstrous TB's are not need. GM didn't seem to think so on the Ram Jet.
Old Jan 22, 2002 | 10:05 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Comments?
Mark.
true but I bet that a 350 could make 1hp/per cubic inch with a 48mm as well. Maybe they messed around until they got the advertised 502 hp from it
Old Jan 23, 2002 | 03:31 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
GoFasterFirebird, what role do you think plenum volume plays in TB selection? For example if you had a 406 LTR TPI and a SuperRammed 406, all else being equal, assuming ideal air delivery after the plenum, which one runs out of breath first?
Old Jan 23, 2002 | 07:52 PM
Guest
Guest
Posts: n/a
I could be wrong, but I dont recall that the 502 Ramjet has any claims that larger TB's did not improve the power output. The air demand of that engine is also entirely different and hard to compare straight across to a 350.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Thornburg
Aug 27, 2015 08:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
