TPI bogging down under acceleration
Old Jan 19, 2022 | 08:06 AM
christianlib.18's Avatar
Car: 1987 Camaro Z28
Transmission: t-5
Hey guys i'm having an issue with my 87 z28 5 speed. The car normally runs fine but when I was driving this morning and I really gave it some gas the I noticed that the car was hesitating and bogging down. I had been driving the car for about 5 minutes so the car was somewhat warmed up. I just recently replaced the fuel filter and I am wondering what is causing this issue. Thanks in advance.
Old Jan 19, 2022 | 10:28 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: TPI bogging down under acceleration
vacuum leak/bad gas/sensor problem/timing off, dunno...........was it doing this before you changed the fuel filter?
Old Jan 19, 2022 | 01:12 PM
Transmission: t-5
This happened after I replaced the fuel filter and I do not have any vacuum leaks.
Old Jan 19, 2022 | 01:31 PM
silverstang84's Avatar
Car: 88 IROC
If this a happened AFTER you changed the fuel filter make sure it’s tight and not sucking in air
Old Jan 19, 2022 | 04:42 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Check fuel pressure to make sure it is within spec. Maybe the fuel pump is getting weak. If possible test while driving with a helper to see what happens under load.
Old Jan 19, 2022 | 07:20 PM
Transmission: t-5
The car is only bogging down when accelerating when I first get in the car but the issue goes away after driving for about 15 minutes
Old Jan 19, 2022 | 09:47 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Use an ohm meter to check your coolant temp sensor. 2 pin sensor in the front of the intake manifold.
Then compare your reading to this chart
Old Jan 19, 2022 | 10:36 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Tape a fuel pressure gauge to your windshield and try to reproduce the issue.
Old Jan 19, 2022 | 11:44 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
this. fuel pressure would be the first thing I would checkhere. Its easy to do and if you don't have the gauge they are 35$ on amazon for a quality Bosch kit (example of the one I have)
Amazon Amazon
Only hard part is viewing it while driving... tape works here as Komet said.
Old Jan 20, 2022 | 07:34 AM
Transmission: t-5
thanks for the info guys
Old Jan 20, 2022 | 01:33 PM
LiquidBlue's Avatar
Transmission: MD8
Boy, if it was me, and all I did to the car. ALL I DID, was change the fuel filter, then the fuel filter sure would be prime suspect #1.
Old Jan 20, 2022 | 02:38 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Agreed, I'd also be having a second look at the last changed item.
Old Feb 22, 2022 | 08:56 PM
Nekomancer's Avatar
Car: 1987 Pontiac firebird trans-am
Transmission: THM 700R4
Axle/Gears: 3.27 POSI
Check your fuel return lines. The increase in fuel flow from a brand new filter will often dislodge a piece of debris down the line and if it doesn't hit an injector, or make it safely to the tank, then it could cause problems with fuel return.
806camaro
Dec 8, 2024 08:46 AM
irocttops
Apr 13, 2006 01:10 PM
brimstone
Jun 12, 2003 12:06 AM
87z28TN
Feb 11, 2003 09:01 AM
moronwithtools
Jun 17, 2002 01:09 PM
