Car shakes at 90-95
Old Apr 2, 2002 | 11:37 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Car shakes at 90-95
I have a 89 GTA 5.7L. Like all third gen guys, I like to drive fast(that is what the car was intended for). When I get to about 90-95MPH the car starts to shake a good amount. I mainly feal it in the wheel and center counsil. Has anyone else experienced this? Has anyone found a cheap way to fix it?
Thanks Brian
Old Apr 2, 2002 | 12:27 PM
87transam5.7tpi's Avatar
is your tranny mount good? mine was crap when i got my car, and going down the highway after I put it in I hardly knew the car was running. (that was before the new exhaust :-) )
Josh
Old Apr 2, 2002 | 01:01 PM
Drew's Avatar
How recently were your tires mounted/balanced? if you're confident they're balanced correctly, look into an aluminum driveshaft.
Old Apr 2, 2002 | 01:04 PM
sIcK pUpPy's Avatar
I had the same prob. I replaced my center link and tie-rod ends (worn to hell) and the situation was resolved.
JD
Old Apr 2, 2002 | 01:15 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Well you already have a stock aluminum drive shaft, so you can probably rule that out... check the tires like was said above.
Old Apr 2, 2002 | 01:50 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Thanks, I will have to look into all of these.
Old Apr 2, 2002 | 02:08 PM
86Z28TPI's Avatar
Also: Don't forget: Even if you replace all these components, there is still the "road resonance" factor. When the vibration harmonics of the road match that of the suspention you get shaking (usually light) in the front end. It happens in every car and is normal. It usually happens around 70 to 75 mph, and if you keep accelerating it stops. My 86 vibrates from 75 to 80 but is fine from 0 - 75 and above 80. Just a thought.
Old Apr 2, 2002 | 02:45 PM
thats true man, same thing with my car at time, but also remember cops don't fall for that excuse :-) LOL
Old Apr 2, 2002 | 03:13 PM
86Z28TPI's Avatar
Right! I just drive 90 and blame it on the road. Cops? What cops?
Old Apr 2, 2002 | 05:41 PM
90Form350's Avatar
88 WS6 TransAm GTA Well you already have a stock aluminum drive shaft, so you can probably rule that out... check the tires like was said above.
Why would he have a stock aluminum driveshaft?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
