ive got problems withthe good 'ol (?) 9-bolt...
Old Jul 7, 2002 | 04:17 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
i need help baaad!!! i have the Borg-Warner 9-bolt rear end in my Formula and i CANNOT make the diff cover seal!!!! i originally tried to fix a simple little leak it had when i bought the car, when i fixed it it seemed to hold for a while, then when i checked it out it turns out that the bolts had backed out, so i tightened them and refilled it. then 2 days ago i noticed that it was leaking yet again. so i got the gasket and took it all apart, put the high tack stuff on it this time to try to get a better seal, drove about half way to a friend's house, stopped at a gas station and i'll be damned if it wasn't leaking AGAIN!!! this is turning into a nightmare for me people! so i drove home, put it back on jackstands, tore it apart yet again, put insta-gasket on it (part stores were closed, used Mekanica Formula RS [anyone familiar with this?] ) let it sit just as instructions said and this morning i go out to the garage and the **** STILL LEAKS!!! WTF AM I GONNA DO NOW!!! i am going crazy trying to fix this persistant problem, do i need to remove the sway bar to get a better angle to make it seal? i think my pan may be warped, i thought this earlier in the adventure so i put it on the garage floor and tried to tap it straight with a hammer, all i accomplished was knocking some of the lip that curls out flat. now im confused, what should i do now? and where do i find a new rear diff cover, www.9bolt.com dont seem to have one or at least i didn't see it
Old Jul 7, 2002 | 05:15 PM
KeithO's Avatar
The only things that come to mind are:
1) Torque the bolts to 20 ft-lbs - that's what my Chilton manual says.
2) Make sure you tighten the bolts from the center out, alternating sides (like how you tighen wheel lugs)
Other than than, I'm stumped.
Old Jul 7, 2002 | 07:05 PM
thanks man, i listened to a friend who said he'd done it before. i didn't ask him, but he heard of what i was going to do and said to MAKE SURE i did the following:
A) TORQUE THE FU(K OUTTA THE BOLTS (mistake #1)
B) put RTV on the gasket (mistake #2)
listenin to him (mistake #3) so now, unless i did it right this time, i will do it the proper way, man i feel like the world's biggest jack@$$!!! my poor Formula!!!
Old Jul 8, 2002 | 12:23 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
They are on the order form list about 2/3 the way down.
Miles
Diff Solutions
www.9bolt.com
Old Jul 8, 2002 | 12:56 PM
hey thanks, must have overlooked them! one question though. do any of you guys know of any company that makes a chrome diff cover for the 9-bolter?
Old Jul 8, 2002 | 03:55 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Nope, but I'm working on an aluminum girdle with bearing cap supports now. Was hoping to have it available already, but other business issues took precedence. It will be later this summer though.
Miles
Old Jul 11, 2002 | 08:39 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Miles, I saw rear diff cover plugs and gaskets, but no diff covers themselves. Did I overlook them too?
Also, would you have any input on this backing plate topic?
https://www.thirdgen.org/techbb2/sho...hreadid=115692
Old Jul 11, 2002 | 09:47 AM
Steve89GTA's Avatar
I didn't even use a gasket just good ol blue gasket seal from permatex. Has not leaked one bit for 3 years.
Old Jul 11, 2002 | 10:30 AM
you never change your fluid? geeze 3 years? that s what i did anyways, mine don't leak anymore either
Old Jul 11, 2002 | 12:10 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Sorry, my bad I didn't catch that it was just a cover you were looking for. The aluminum ones should be available sometime soon (this summer). I do have a few used factory covers, but there are $45 each.
Miles
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
