simple question: how many quarts of ATF does will my car hold??
Old Jul 16, 2002 | 06:53 AM
Don_89Iroc's Avatar
i just need to know how many quarts of tranny fluid i need to put in my tranny when i change the fluid
Thanks, - Don
P.S. its a stock 700r4 tranny
Old Jul 16, 2002 | 07:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Simple answer requires another simple question...
How much of the fluid are you changing?
If the trans and converter are completely dry, it takes about 23 pints. If all you do is drop the pan (leaving the converter and most of the internals full), it takes about 10 pints. If you at least take the cooler lines loose and blow them out, it will take another pint or so.
Old Jul 16, 2002 | 07:49 PM
Don_89Iroc's Avatar
i plan on just droping the pan and changing the filter, i bought 6 quarts
Old Jul 19, 2002 | 06:23 AM
Don_89Iroc's Avatar
will somone please reply :hail: i really wanna change my fluid i just plan to drop the pan and change the filter, how many QUARTS of fluid will i need to put back in???
Thanks - Don
Old Jul 19, 2002 | 07:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Elementary school units of measurement lesson:
1 quart = 2 pints
6 quarts = 12 pints
Service manuals always give trans capacities in pints for some reason
You'll be fine with what you've got.
Old Jul 19, 2002 | 11:48 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
Thanks - Don
ok i have to make a smart remark, you need as many quarts as it takes to fill it
now on a serious note, i "think" its about 5, if you are just dropping the pan, could be more or a little less, when i did mine i started with 4 quarts, then checked it and added, till it was full,
remember you can't check a transmission when the car is shut off and dead cold, its gotta be warm and idleing on flat ground
Old Jul 19, 2002 | 08:43 PM
laiky's Avatar
5 quarts
5 quarts
put 4 in then chech it with the engine running after you cycle it through the gears
park, reverse, nuetral, drive. engage each position for about 10 seconds, then check it
Old Jun 3, 2017 | 06:17 AM
Barry Pearson's Avatar
Re: simple question: how many quarts of ATF does will my car hold??
​​​​​​​Hey Mr. Don't, I am facing the same dellima with my 1990 Corvette. However. I decided to do it the old skool way instead of getting a bunch of misinformation. Listen Mr. Son, when changing your ATM fluid be sure to capture the used fluid in a drop pan, take a old ATM fluid bottle and measure every bottle of fluid that you take out (re-place)old skool!!!
Thanks, - Don
Old Jun 3, 2017 | 01:46 PM
OrangeBird's Avatar
Car: 1989 Firebird
Nice 15 YEAR thread necro , dude ..... And , while we're on the subject of stupid misinformation , your "method" sucks because it PRESUMES the transmission is properly full when you begin draining it , and in the real world , it is gonna be likely that a transmission or two out there just may have less than the right amount of fluid in it for any number of reasons .
God , and the General at General motors , both got together and decided that your transmission should have an easy and accurate method of determining the fluid level . This wonderfully simple device , known as a "Dipstick" , is to be trusted over any other nonsense such as measuring the old dino squeezins on their way out , relying on "Karma" , or using "The Force" .
PS , welcome to TGO ..... I think ...
Old Jun 3, 2017 | 01:49 PM
OrangeBird's Avatar
Car: 1989 Firebird
Yep , "channeling" Sofa ain't easy , but Gee Willakers I think I got the hang of it !
Old Jun 4, 2017 | 02:33 PM
clubber's Avatar
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
Yea but it's atm fluid so who have to know what bank it's from.
Sorry I had to.
Old Jun 4, 2017 | 04:43 PM
ATM fluid
Can I use blinker fluid if my local parts store doesn't have version 6.3.1.4a of that? Or would it just be better to grease my Z71 muffler bearings at that point?
Old Jun 4, 2017 | 05:43 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
going back to the teen years of installing trans for a job.. dry off the shelf 10 to 12 QTs. filter drop 4 to 5 qts..
Old Jun 4, 2017 | 07:23 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
I don't know if he wants the competition. Sofa's gonna have to take it to a new level now.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Wade787b
Sep 29, 2015 01:15 PM
mizz0313
Aug 12, 2015 06:45 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Exxon Limited
Aug 9, 2015 08:13 PM
