Do all IROCs come with stall converters?
Old Aug 15, 2002 | 10:25 AM
N8Miller's Avatar
my one friend has a stock 88IROC and he is desputing right now that all irocs come with stall converters. He can "stall" it right now to about 1500 or so, but is he just really powerbreaking? oh, by the way, at the track, if he doesnt have a stall converter like he says, he blew out drive and overdrive------and is looking to buy the tranny from my cousin in the previous post of mine for like $600 or less...is that a good deal, brand new 700r4?
Old Aug 15, 2002 | 10:37 AM
ede's Avatar
ede
only the automatic have stall converters i think it's cute how you call them "stall converters" what exactly is the differance between a stall converter and a non stall converter? there is no such thing. all converters stall to aset speed or rpm depending on HP and weight and flash at a certin rpm.
Old Aug 15, 2002 | 01:35 PM
flyin89's Avatar
According to information I read in a S/10 swap manual(which I have loaned to a friend) the stahl speeds between a 350 and 305 TPI are dif, the codes were in the book, but the 305 had a higher stahl speed (supposedly 2500and the 350 had a decent stahl speed too) TBI engines have a ridiculously tight stahl and the valvebodies are different. Yes a TPI Iroc would have a looser converter.
Old Aug 15, 2002 | 04:02 PM
kevinc's Avatar
Car: 1982 Z28
Yes, they come with stall converters. They also come with horsepower engines, candlepower headlights, ratio rockers, width rims, and pounds/hour injectors.
Old Aug 15, 2002 | 06:19 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you guys
i think he meant whats the stock stall speed on the converter.....................
Old Aug 15, 2002 | 08:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Typical stock stall speed on a factory converter is 1200 rpm. Don't forget that factory tachs are not that accurate either.
The only way to know the true stall of a converter is with a transbrake. Foot brake stall test will not hold the vehicle to the converters stall speed. The engine torque will overcome the vehicle's brakes before the true stall speed is reached.
Old Aug 16, 2002 | 08:03 AM
ede's Avatar
ede
damn kevin now i have to clean the moniter
Old Aug 16, 2002 | 02:40 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
i had a factory stall in my 700, i could only get about 1100 rpm out of it power braking before it would spin tires, or want to slide the front end
Old Aug 17, 2002 | 03:31 AM
transfixleo's Avatar
1397.
Old Aug 17, 2002 | 08:10 PM
OûtlåwFørmûlå's Avatar
Yeah what Kevinc said!
jklein337
Sep 19, 2018 06:23 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Wade787b
Sep 29, 2015 01:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
mustangman65_79
Aug 11, 2015 03:17 PM
