28-spline axles
Old Sep 9, 2002 | 08:08 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
28-spline axles
where can i get a nice cheap set of 28-spline axles so i can get a posi in this one wheel wonder of mine relativly inexpensively? im having trouble w/ junk yards as the people that run them are complete idiots.
Old Sep 10, 2002 | 05:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The only factory 28 spline axles that you can find that will be a direct fit are from 90-92 f-bodies. There probably won't be many choices of those in the junk yards.
You can get much better aftermarket 28 spline axles from places like www.drivetraindirect.com for $125 each.
Old Sep 11, 2002 | 12:05 AM
i thought 88 and 89 had em too
Old Sep 11, 2002 | 10:44 AM
AlkyIROC's Avatar
Car: 87 IROC L98
If they did then they were a special factory install. Officially they were never standard issue until 1990.
There's a catalog listing for the axles on www.tomsdifferentials.com
Old Sep 11, 2002 | 10:50 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I had my hands on a set... then the f'ing pinion lock bolt snapped. I hate that damn bolt. Couldn't get air or power out to the car (in a junkyard), couldn't work the bolt fragment out with a pick, and after trying to break the case apart with a hammer & cold chisel, all I did was put some chips in the center (no room to swing a hammer). I was so mad... dammit!!!
Old Sep 11, 2002 | 06:48 PM
ergh
Old Sep 11, 2002 | 08:46 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Stephen, forgive me for being a rookie but aren't you the guy who was running 26 spline axles well into the 11s?
Old Sep 11, 2002 | 10:03 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
If you need axles check out these people. If you buy their Torsen unit, you can get axles for $50.00 more. Not a bad deal.
Ebay auction
Old Sep 11, 2002 | 11:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I never used 26 splines. I ran high 11's with a stock 3.27 geared 9 bolt. When I built up a 10 bolt I used Tom's KA 28 spline axles and ran as quick as 11.24. My 9" has 31 spline axles.
Old Sep 12, 2002 | 12:49 AM
looks good
Old Sep 12, 2002 | 04:17 AM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Sorry, I must have been mistaken. That's still impressive with the 28 splines.
Old Sep 12, 2002 | 03:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What if they're the axles for a 93-up f-body? Then they'll have the ABS reluctor, and won't they also be a bit longer?
Old Sep 12, 2002 | 08:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The 28 spline axles from the 93-2002 are almost 2" longer.
Old Sep 12, 2002 | 08:11 PM
IROCZ315's Avatar
I emailed him. He says he has them for both 3rd and 4th rears but doesn't have any disc brake rears
6speedIROC
16
Mar 15, 2023 08:33 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
