700r4 to th350 question
Car: 86' camaro s/c
Engine: 357
Transmission: th350
I'm switching my crappy 700 out for a built th350 i use in my chevelle. I know i need a b&m kit and different driveshaft, but does anyone know how much longer the driveshaft is. Of for that matter can i use a 9" tailshaft for it and bolt up? thanks
The driveshaft will need to be 3" longer if the TH350 has a 6"
tailhousing. Changing the output shaft and housing to 9" is a
PITA and not free, either. Getting a proper length driveshaft or
shortening one that is too long would probably be the thing to do.
I performed this swap in the past & I used a long tail 350 trans with the stock 700r4 driveshaft. U can also use the stock driveshaft out of the 82-84 3speed auto camaro/firebirds with your short tail 350 trans.
njdaewoo
njdaewoo
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
My Th350
I used my Th350 built to the smae length for 350 bucks and damn she worked good. Bolted right in with a special plate.
Car: 86' camaro s/c
Engine: 357
Transmission: th350
thanks guys, if its only 3" diff, i think i'll just get a longer tailshaft for it as it would be easier for me. Thanks for the help.
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
your not understanding, it's the tailshaft AND the tail housing that need to be elongated. That means the tranny needs to be torn into and it's gonna cost some serious $, get a longer driveshaft, it's cheaper and easier.
www.spohn.com sells a extreme duty driveshaft for the swap. Costs like 300$ but its probably worth it.
Iroc8t8
Aug 26, 2015 08:14 AM
