Th-350 ?
Old Feb 24, 2003 | 12:06 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Th-350 ?
Am I correct: The long tail TH-350 came in 70s and early 80s trucks.
Old Feb 24, 2003 | 12:14 PM
definitive1's Avatar
Got mine from an 82 truck. Longtail.
Old Feb 24, 2003 | 06:22 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
got mine from a 78 2wd pickup
long tail
also got my 350 out of it.........oddly enough its a 4 bolt main
i'm guessing the truck was a 2500 series
Old Feb 24, 2003 | 09:22 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Got mine from 74 Caprice
Old Feb 24, 2003 | 09:27 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
long tail
Almost all trucks are the 4 bolt block. Even more so back in 78. 1/2 ton or 3/4 ton didn't matter.
As for Brodyscamaro. Yes I beleive you are correct. The th350 I used on my L98 in my SS came from a Malibu. Worked perfect without any shaft problems mind you it used a 2004r originally.
Old Feb 25, 2003 | 09:22 AM
fastcamaro350's Avatar
Will a 9 inch tailshaft fit on a transmission with a 6 inch tailshaft without problems?
Old Feb 25, 2003 | 09:37 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I don't think so, but I am not 100% positive though either.
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sure, the longer extension housing will work, if you take the trans apart and put in the drum with the longer shaft too.
Old Feb 25, 2003 | 10:30 AM
i always heard that 2wd trucks were almost always 2 bolt mains
:shrugs:
Old Feb 25, 2003 | 12:27 PM
What do you guys think the most I should pay for the transmission is? That is if I can't find one for free. I was thinking of paying no more then $125 or $150 bux for one - and prolly cheaper.
Old Feb 25, 2003 | 12:55 PM
cashman's Avatar
i got my full race tranny for 300 bucks(not including driveline lenghtening, custom xmember, etc) of course i knew the guy, so i got the core for free, he charged me 100$ in labor, and at the time i worked at a parts wearhouse, with 30% discount. anyway its b&m threestage shift kit with some drilled valve bodies and some of the fundamental stuff to turn grandmas th350 in her boat to a firebreather. now it may sound like im blowing a lot of smoke, and i am, my point is dont pay too much, th350s are common and the upgrades are cheap. you could probably do the labor yourself if you had a good step by step manual(not sure where to find one) anyway, thats my 2 cents worth, and remember if u do it yourself remember, CLEANLINESS. And as i final note, i recommend the swap to anyone that can, u wont believe the difference between your 700r4
Old Feb 25, 2003 | 01:30 PM
IHI's Avatar
IHI
If your talking a price on a TH350 from a junk yard, I don't think they'd cost over $50, around here they range from $25-50 anyways. I've personally got NO luck with used stuff, so I either buy new or have whatever completely rebuilt, now my chince buddy won't spend money on anything, he always buys trannies straight from the junk yard for his projects (last one had 1" sludge & crud in the pan) he has me put in a B&M shift kit and calls them good-lucky bastard has yet to have a bad tranny. Back in high school (81 Monte) I did this with 4 trannies in a 2 week span, needless to say by the 3 & 4th time I could have it back on the road in less than 2 hrs from the time I first started-I never want to be that efficent again
Old May 18, 2003 | 04:38 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
trucks from 69-79 were 4 bolt mains 2wd and 4x4 both, after that they could be either and mainly 4 bolt in the 3/4 and 1 tons
long tail trannies in all 2wd trucks after 72, 4wd tryucks have no tailshaft housing at all
TexasMaro
Sep 15, 2015 06:50 PM
Dan83
Jul 19, 2003 03:30 PM
Changa2
Mar 31, 2002 03:09 PM
88 Formula
Mar 15, 2002 07:31 PM
chicksL69
Nov 8, 2000 06:24 AM
