is this too radical or is it streetable?
Old Mar 1, 2003 | 08:04 PM
rockfourone's Avatar
ok i found a rear end with some richmond 4.10 gears in it. the rear is a posi with less than 2k miles on it. i got a really good deal on it but i just want to know, is 4.10 too much for the street or is it not that bad???? btw its going behind a 355 and t-5. thanks in advance
Old Mar 1, 2003 | 08:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Depends on the 355.
Personally, I think you'll like it.
Old Mar 1, 2003 | 10:04 PM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
If you had a 700R4 the gearing would kill your top speed and your gas mileage, but with the T-5 it should work great. You'll have to get your speedo recalibrated too, it;s really going to throw that off. You'll love the gears though.
Old Mar 2, 2003 | 11:21 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You will like it. I just put a 4.56 setup in my truck that had 3.73's hehe more is never enough with a standard and mine is only a 3 speed munccie.
Old Mar 3, 2003 | 04:40 AM
laegion's Avatar
Car: 84 Trans Am Ws6
Engine: 305 LG4 "H.O."
Transmission: wc t-5
my personal opinion, if the 355 isn't built, that it's gonna be annoying because you'll run out of powerband really fast, but it will feel really cool when you accelerate and decelerate. that and your gas milage will go to crap. trust me I know someone who has 4.10's, you would be better off with like 3.42's or 3.73's, since you have plenty of bottom end torque with a 355 you could make 3.42's scream.
just my $0.02
Old Mar 3, 2003 | 08:18 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
4.10's are sweet in a 700r4, and even better in a T5. I used to chirp the tires from a stop with both leaving at part throttle from a stop light.
Old Mar 3, 2003 | 12:43 PM
well ideally id go with 3.73s but i got a great deal on a built 10 bolt with 4.10s. (140$) so all i want to know is, will it really hurt me or can i still drive around town and be ok? also, whats the RPM gonna be like at about 70mph?
btw- my 355 is built from the pan up. 194in/177ex, lunati cam, high comp 11:1 pistons, etc......
Old Mar 3, 2003 | 02:24 PM
laegion's Avatar
you'll be fine. just don't give yourself whiplash!
Old Mar 3, 2003 | 04:41 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You'll like it.. my T5/3.73s give a massive launch when you want them to, and a 4.11 will only be a harder launch
Old Mar 3, 2003 | 09:34 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
<b>btw- my 355 is built from the pan up. 194in/177ex, lunati cam, high comp 11:1 pistons, etc......</b>
How much duration on that cam at .050, and is it a roller?
if you have over 224*-230* of duration @ .050 i would say go for it.
anything less, and you'll shoot right over any useable engine power with 4.10's, 3.73s would be pushing it.
not that it wouldnt work, but for such serious gears, your motor has to love to spin.
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Brad
Aftermarket Product Review
Nov 3, 2000 03:34 PM
R.O.B.
Sep 26, 2000 03:45 PM
motley400RS
Aug 1, 2000 09:14 PM
