How do you install trans cooler?
Old Mar 18, 2003 | 11:50 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I just bought a trans and I got a trans cooler with it too. Where and how do you install it?
My guess is that it threads into the input or output trans fluid lines, but which one?
There are a couple rubber connectrors.
Old Mar 18, 2003 | 12:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
www.transamtemple.com
check it out in there he has a trans cooler installed with pics.
Old Apr 15, 2003 | 07:45 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Anyone have any better installs?
Old Apr 15, 2003 | 10:05 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
http://home1.gte.net/res0t8sj/tcooler/
No pics of it installed because i still am using temporary means. Strapped to the X brace on the driver's side so the primary fan will draw through it in traffic. You can get the idea from the fittings though how it's connected...
Old Apr 15, 2003 | 11:06 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You are doing yourself a BIG favour putting in a tranny cooler
It will likely double the life of your new tranny
Old Apr 16, 2003 | 01:30 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I bought the Hayden version of the same B&M that you are using. The thing that got me was getting the lines from the transmission connected to the cooler. Those lines do not bend. I guess I will have to get some adapters to go from the tranny lines to the cooler. I thought the cooler came with all the parts needed for install.
Old May 17, 2003 | 11:46 AM
OMINOUS_87's Avatar
If i were to use the stock hard lines from the trans till they reached near the where they enter the radiator and then cut em and ran the larger size hose to the cooler from the cut point mounted in front of the AC and radiator how would this affect the flow and pressure of the fluid?
Old May 17, 2003 | 12:51 PM
EvilCartman's Avatar
Car: '82 Z28
I just installed a temp sensor inline after the B&M cooler this past week, finally went for a drive last night and tranny temps were anywhere from just over 100 while cruising to 150 after going up a long steep hill
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
TheJoeY88
Aug 13, 2015 06:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
