Got My T5 in......
Old Mar 27, 2003 | 01:08 PM
TwistedIROC's Avatar
Got My T5 in......
Well, after a little minor problems, I switched from an auto to a T5 and now I get a check engine light, setting a TCC code, now my question, would it be possible to solder in a resistor in the tcc harness between the feed and return wires to the ecm, since all it is looking for is a change in voltage?
Kyle
Old Mar 27, 2003 | 01:23 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You could do that, or disconnect the dummy light. I'm not sure what you would use to do that though...
Old Mar 27, 2003 | 01:25 PM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
Yes, this also works for temperature sensors on the newer f-bodies. You take a resistor and solder in place of the sensor. Just look up what the sensor is supposed to read and go to radio shack and pick up that resistor. It should work fine.
Old Mar 28, 2003 | 01:13 PM
Well, now it is giving me another code, a code for a no vss, my car is cable driven speedo, so where is the vss signal derived from.
Kyle
Old Mar 28, 2003 | 01:48 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
I did the t5 swap in my 84 and i get a vss code too, only when i drive on the highway... My car also has a cable driven speedo..
Old Mar 28, 2003 | 09:19 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
your car gets the VSS signal from the back of the speedometer after you pull the cluster out you will see the sensor
Old Mar 28, 2003 | 10:13 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
why does a mechanical or cable driven speedo recieve a vss signal? That is weird......How can a correct the problem?? Thanks Kevin
Old Mar 29, 2003 | 08:06 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
The speedo does not recieve the signal, the cable just turns the VSS sensor behind the speedo, then the signal goes to the computer so it knows how fast the car is going, and if you have cruise control it uses it too.
Old Mar 31, 2003 | 02:55 PM
Thanks for the help I am getting a converter for the signal at the trans and it is supposee to plug in and run the cable.......from what I could gather from the guy I'll keep you posted and let you know how it turns out.
Kyle
Canadian Girl
Canadian Region
Jul 2, 2012 04:05 PM
online170
Theoretical and Street Racing
Sep 16, 2008 01:11 PM
v10viper04
Oct 18, 2007 11:39 PM
whyt86roc
Sep 4, 2007 09:50 PM
