Running a 700r4 without lockup
Old Apr 3, 2003 | 06:49 PM
Duke901's Avatar
Car: 89 Formula
I have a 85 iroc with the 700r4. I want to change it to a carb and get rid of the computer. So i want to run the tranny without the lock up torque converter, but iam worried that i will mess up the tranny if i do so. So can i do that or would i have to keep the computer to use the lockup.
THANK YOU
Old Apr 3, 2003 | 07:20 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i have a 700r4 raptor and i dont use my lockup. however you need to be sure what year your tranny is because they changed them in 85. 85 and later you could unhook the lookup but 84 and older will overheat.this is to the best of my knowlege and not based on 100% fact. see www.700raptor.com they can help you.
thanks
Old Apr 3, 2003 | 07:27 PM
Duke901's Avatar
Car: 89 Formula
Well, the tranny was rebuilt about a year ago. Why i want to change is that the lockup comes in very very earlier. Do u think maybe i should get a tranny cooler.
Old Apr 3, 2003 | 07:58 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
I am in the a similiar situation. I replaced factory computer with the FAST system and now need to think about my lock-up. Painless wiring sells a product that allows you to use 4th gear lock-up without the computer in the 700R4. Summit part number is PFR-60109.
Old Apr 3, 2003 | 08:21 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
I don't think it will hurt it to run in unlock. I have a carb 84 Z28 and it used to go into lockup too soon. I put a toggle on the control line and run it around town with the switch off and in unlock. On the highway I switch and let it go into lockup. I have an 85 iroc with a 700 and a ecm. It likes to switch at 45 mph and sometimes I don't want it to do that. Where I live the road is winding and the speeds seem to be between 40 and 50 so it is locking and unlocking so once again I put in a toggle and leave it unlocked. Flip the switch on the highway and back into lock. So my guess it it won't hurt it.
Old Apr 3, 2003 | 08:26 PM
Duke901's Avatar
Car: 89 Formula
If i wanted to keep the computer and run a toggle switch, how would i go about doing that.
THANKS
Old Apr 3, 2003 | 08:52 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
check out the article on hooking up your tranny lock up it will explain it all.
thanks
Old Apr 3, 2003 | 08:54 PM
Duke901's Avatar
Car: 89 Formula
Ok thank you
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
There is a pink/blk wire ( 39 on wire diagram ) that goes from the ign to the brake switch, then on to the trans and back to the ecm where the circuit is completed on a ecm car. On a carb non ecm the wire goes to a vacuum switch in the engine bay and then to the brake switch. If you tap in anywhere before the brake switch with your toggle should do it. On my tpi car I hooked it up just before the ecm because it was easier for me as I had it out. That is a tan/blk wire 422 at the ecm.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
