trans go shift kit install
Old May 27, 2003 | 09:11 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
whats up i'm looking at getting trans o shift installed in my 89 iroc 700R4 tranny
i wanna know 2 things, where and what kind/which to get the kit from and ow hard it is to install the shift kit or should i have a shop perform the instalion?
thanks-jonathan
Old May 27, 2003 | 09:23 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
According to the Transgo site you only need normal hand tools to install the shift kit.
As for the reliability, I've heard two stories to this. One of them is a personal testimony from someone I've met in person.
Everyone raves about the TransGo shift kit, I've never read anything bad about it.
Some people have posted bad stuff about the B&M shift kit, but AJ_92rs has one in his tranny and he hasn't had any problems with it. Says it works great.
Old May 27, 2003 | 09:30 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I got my kit from Thunderracing.com. I am very pleased with mine. The install wasn't all that bad, comes with paper and video instructions. All you have to do is make sure you take your time, and follow directions closely. It took me about 3-4 hours to complete it, but I also had to pull the pan again and I didn't know anything about trannies.
Old May 27, 2003 | 09:50 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I have a trans-go kit in my tranny. I like it. Shifts normal at light throttle but shifts pretty hard at WOT I like it.
I say the best 2 mods to a 700r4 are the trans-go kit and a cooler...at least for mild engine
Old May 27, 2003 | 09:51 PM
FruityOne's Avatar
Probably a dirty job too. I'll be buying one of these in a while if this tranny holds up well.
Old May 27, 2003 | 11:11 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I installed a trans-go shiftkit in my car last summer. Then I uninstalled it and reinstalled it about 6 more times because it didnt work right, with the same problems after each time.
I called trans go many times and they were pretty much baffled by the end. Look and my sig and you will see a probuilt trans now.
Install at your own risk.
Old May 28, 2003 | 10:53 AM
Transmission: 4l60e
I watched the video a couple times and I thought I could do it. Looks pretty simple you just need to take your time and dont rush.
I sold the kit and ended up getting a tranny that already had it installed. Made things easier for me.
Old May 28, 2003 | 04:30 PM
Engine: peanut LB9
what was the problem?
Old May 28, 2003 | 04:49 PM
Car: 92' RS
Engine: LO3
Well the main problem was that I lost 1st gear for the most part, it would work under low throttle, but any more than 1/4 throttle it would go right into second. Then when you put it in 1st manually it would work but when it shifted to second it took about 3 seconds and it chifted so softly the engine would redline.
At WOT it would not shift from 2nd to third gear, sometimes.
And a couple times when it was in OD and I went to WOT it would not go into 3rd, which should be impossible for this trans :shrug:
Well that was my experience, there are a lot of people who have done this with no problems. And I watched that video many many times and step by step as I was doing it.
Old May 28, 2003 | 06:04 PM
irocz28adl's Avatar
Well, personally I've never heard anything bad about transgo either, which is why I bought mine. I tried the whole install it yourself deal, didn't work for me. Everything went fine, just when I put it all back together it skipped 2nd and didn't go into OD. So I ended up taking it to a shop, having it installed right and got the tranny rebuild too. I would definately recommend taking it to a shop to have done because you'll get the best results that way and it saves you a bunch of time. Good luck! (BTW, it definately chirps in 2nd and I only have an 87 LB9)
Old May 29, 2003 | 02:56 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i installed the transgo kit i got from summit. comes with video and manual, so i had a tv outside in my driveway. it was pretty simple. change some springs and valves, cover some holes in the separator plate, drill some holes in the valve body. and install the vette servo. i installed this on a tranny with 110,000 miles and it is still working. whould always chirp 2nd and 3rd would pull hard, this was all on a basicly stock 305tbi. so any more engine mods would of had 3rd chirping too.
Old May 31, 2003 | 01:25 AM
25THRSS's Avatar
How is your part throttle shifts? Are they harsher than stock, softer, the same, or what?
Old May 31, 2003 | 08:55 AM
Guest
Guest
Posts: n/a
i have the TransGo kit and it kicks ***! the B&M kit doesn't some with the 'Vett servo like the trans go kit. its more money and its well worth it. ($129.95 from sumit.com plus shipping) my friend has the B&M shift kit in his car and it shifts car but mine shifts a hell of a lot harder and it will chip the tires goign into 2nd and 3nd
Old May 31, 2003 | 08:58 AM
Guest
Guest
Posts: n/a
ever time you see the video like pause for a sec thats when the guy is going "OH #%#%$! #%@ Damnit! son Of A $^!#@" LoL the trans go it is not for someone wo doesn't knwo what they are doing... installing it wrong will fry the trans
Old May 31, 2003 | 09:01 AM
Guest
Guest
Posts: n/a
after reading some of the programs people have with installing the kit it sounds liek you didn't adjust the TV cable right.... on a 700R-4 the TV cable tells the trans when to shift and how hard how fast ect.
Old May 31, 2003 | 07:12 PM
white89_350's Avatar
I have installed the transgo kit and I took the pan off 3 times and the VB 2 times and I can not find out why the auto will not shift into 2nd or 3rd or OD. I have nothing but reverse and 1st. I have posted here a few times and no one seems to be able to tell me a good answer. I have finnally decided to tow the '89 formula 350 to a tranny shop!! So much for saving money.
Old May 31, 2003 | 08:46 PM
Guest
Guest
Posts: n/a
well i didn't install mine i hid my friend do it. so i can't get any more info... other then maybe the check *****??
Old May 31, 2003 | 08:54 PM
No it's not the check *****. I have double checked that.
Old May 31, 2003 | 09:31 PM
Guest
Guest
Posts: n/a
i don't know then.... my only other guess is that it may be the shim on the band?
Old May 31, 2003 | 09:37 PM
jgifford's Avatar
Car: 1986 Z28
When I had my 700 rebuilt several months after I installed mine, They told me that I had a little too much space where I should have had a thicker shim, but I had all my gears. Except for reverse anyway. Turned out, the first time I put everything together, I had all 4 wheels off the ground, and when I tested for all gears, I have no reverse. But I fixed that, pulled the pan and found a valve, spring, spacer, and a few other items that I had not put the snap ring in right, so it didn't hold when it had pressure.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
