LSD vs. Posi?
Old Jun 9, 2003 | 01:04 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
LSD vs. Posi?
I'm lookin for a diff. that would let me corner well, but will completly lock the rear together if I have the pedal down with no problemb, 'cause I drift (well I try anyway...), and someone said that a Posi won't lock up if your turning at all, and all the Japaneese drifters use LSDs. Anyone know any better?
Old Jun 9, 2003 | 02:21 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
For your info a "POSI" is a Limited Slip. GM's name for its Limited Slip or Posi-Trac Rear. Also it was not designed for what you are attempting to do. I think you seen to many Movies like Jackass and Dumb & Dumber .
Old Jun 9, 2003 | 02:45 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i am pretty sure that posi was actualy a mopar name.
Old Jun 9, 2003 | 02:48 PM
DJP87Z28's Avatar
Also I am POSITIVE and not like you.
Old Jun 9, 2003 | 04:17 PM
82camaro's Avatar
Car: 82 camaro SC
POSI, from the early days it was called positive traction, then positraction, now commonly called posi. Anyway, it's just a name for Limited slip.
Old Jun 9, 2003 | 04:23 PM
SLP_GTA's Avatar
Nope, Mopar use sure grips
Old Jun 10, 2003 | 08:54 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Actualy a posi is different than an LSD. They do the same thing, but in a slightly different way. I've just never driven a car with a posi and was wondering if it would lock it up or if I needed a real LSD. I don't know what they did on jackass, but I'm sure it wasn't drifting...
this is drifting...
http://videl.ics.hawaii.edu/~jaye/videos/
some of those are actualy a guy from this board, REVLIMIT
Old Jun 10, 2003 | 09:15 AM
82camaro's Avatar
Car: 82 camaro SC
Nope, just a name commonly used to describe limited slip. Limited slip comes in many different varities: cone type clutch, disk type clutches, 'torsen' clutchless, etc.... Posi is just the common name that 'stuck' over the years to describe a car that applies power to both rear wheels via some type of limited slip. Other options is a locker(locks or unlocks the rear wheels--no in-between) or a spool(both tires spin at the same speed at all times), or an open rear(the tire with the least traction gets all the power).
Please explain...my guess is that your are talking about the different types of posi/LSD.
Old Jun 11, 2003 | 02:23 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Yeah, I was talking about different types of LSDs.. just not in a ver clear way. Sorry. I guess I ment to ask what type of LSD would be the best for what I want to do?
Old Nov 30, 2003 | 01:42 AM
joshwilson3's Avatar
KO1
16
Oct 15, 2015 05:00 PM
Bigold4x4
Sep 28, 2015 05:21 PM
