whats wrong with my tranny??
I got a little problem over here..when i drive my car it changes gears just fine(normal driving) but when i floor it all gears change between 5k and 55k rpm but 4th gear will not engage..it went up to 6k rpm and it was still on 3th gear...is a 700r4 tranny..any ideas what could be wrong?? Thanks
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
in stock form a 700r4 will not go into or stay in overdrive at full throttle, i believe all you get is approximately 1/3 throttle, or a little more before it either kicks down or just doesn't upshift. its a gm factory way of keeping speed freaks from killing themselves as often
is there any way to change that? Of course,beside replacing tranny
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
I heard having the valves opended up abit...(fluid holes bigger) will give better shifts, rather than shift kits which are
By Example: The 700R4, and Why I Do Not Recommend Shiftkits in 700's..." Is a good reading material
http://www.technicalevolution.com/niceshft.htm
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
