Anyone with 305TPI & 700R4 running 4.10 gears?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am getting a 99 LS1 rear with brakes, LCA relocation brackets, etc..... but it has 4.10 gears and I want to put it on my formula until my trans am is done.
Anyone running this combo?
How bad/good is it running that high of a gear.
thanks
thanks
gas mileage goes down the toilet
it wont be too good on the highway (revs high)
serious burnouts though
not going from experience, just listening to a lot of posts about it
also, im takinga guess on this one
it will be out of its powerband a lot quicker
usually it takes the revs up higher therefore more out of a 305/350 powerband
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
you probably wont be happy with those gears since tpis make all the power down low, traction will definalty be a problem
youd be better off with 3.42s or 3.23s
youd be better off with 3.42s or 3.23s Thread Starter
I am going to eventually put the 3.73 rear end on the car when my brother decideds to get his 4.10 rear repaired.
His broke rear is on my T/A, my 3.73 rear is on his T/A, and this new 4.10 rear will eventually wind up on my T/A but I want to try it on my formula.
I don't want to put the new 4.10 rear on my brothers car since he has broken 10 rear ends already.
As a matter of fact, my 3.73 rear that he has now had 3.42's but he broke my gears right after we bolted my rear to his car. Went down the street and the pinion teeth sheared off.
Here is a sample,
Here is a sample,
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
I am running a 350 w/ 700R4 with 4.10 gears....
70 MPH is at 2900 RPMS, I make trips from Detroit to Chicago all the time and have no problems.
Gasmilage went from 19 Highway to about 16.
Last year was 13.1 w/ 1.87 60' with 3.45 gears. Will see in a week and a half what it does with 4.10's.
I'll be grabbing the rear this week. I don't know if I am going to put it on the formula though, just sold my OZ wheels.
Originally posted by Z28guy83
i think you should give me your 4:10's you can have my 9bolt >:P
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
