Where can someone find a set of 4:11's?
Old Sep 8, 2003 | 03:45 PM
firebird frenzy's Avatar
well same as title 4:11 posi
Old Sep 8, 2003 | 04:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.drivetrainspecialists.com...=28&cat=GM+7.5
No 4.11s (9 and 37), but they do have 4.10s (10 and 41).
Old Sep 8, 2003 | 07:19 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
used? S10 trucks
Old Sep 10, 2003 | 10:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
BTW... its not "4:11" its "4.11:1".... like "4.11 to 1"
Old Sep 11, 2003 | 05:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
used? S10 trucks
Same deal... no 4.11s, but some came with 4.10s
Old Sep 13, 2003 | 06:53 PM
darbleinad's Avatar
Car: 84 Trans Am
to the best of my knowledge, the 4.11s that i just swapped in may car came from an 80s S-10. the gearset is a GM factory set...it was stamped right on it. also stamped right on ithe set was 9 and 37, so i know for a fact it was a 4.11 set. what else could they have came from...an astro/safari van? some g-bodies or a-bodies? (i was under the impression that these cars, like f-bodies never came with anything higher than a 3.73 in them from the factory).
Old Sep 13, 2003 | 07:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Wow, I've never seen 4.11s for a 7½. Lots of 4.10s, no 4.11s. My apologies.
Probably came from a S truck.
Old Sep 13, 2003 | 10:54 PM
Engine: ls1, LB9
yep, thats where I got my 4:11 gears (80's-up s-10) you can get just about any ratio from them and pick the sets up for 30 bux, of course I use the 9bolt now though.
Old Sep 14, 2003 | 03:04 AM
darbleinad's Avatar
Car: 84 Trans Am
well thats what the guy that i got them from said they came from, but i trust your opinion and knowledge alot more than this guy since i only talked to him for about 3 minutes when i gave him my 25 bucks canadian for the ring and pinion set.
either way, i do know that blazers/jimmies, and s-trucks had factory 4.11 or 4.10 gears, especially some of the 2.8 equiped blazers/jimmies.
specialized
Jun 18, 2022 09:26 AM
mustangdmurder
Aug 21, 2015 07:17 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
gta power
Aug 13, 2015 06:15 AM
