Website for speedo gears in the tranny???
Old Nov 2, 2003 | 04:56 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I remember a post a while back that showed a website which showed what tooth gears you need based on rear end gearing for the speedometer to show the proper speed. I tried to search but couldn't find it again so if someone would be nice enough to help me out and send me the link again I'd appreciate that very much. Thanks.
Old Nov 2, 2003 | 05:02 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Here ya go:
http://www.700r4.com/speedoCalc/speedocalc.html
Old Nov 2, 2003 | 06:27 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Here's one for the T5
http://www.hanlonmotorsports.com/T5Speedo.asp
Pete
Old Nov 2, 2003 | 10:05 PM
Bandit5's Avatar
Yeah, i checked those out, some miss a few gear options, just give me your current specs and I will calculate the real most accurate gears. Just tell me what size tires, and rear gears you are running, and I will find you the correct gears.
Old Nov 4, 2003 | 12:49 PM
Opha's Avatar
can someone post the actual formula for the equasion? i've had a goofed up speedo for a year now, and witht he second tranny in with the speed gears not being correct i get a little nervous on the highway.
Tire size: 215-60 r 15
gear: 2.73 i think, unless i was never imformed of them being changed from the previous owner.
Old Nov 7, 2003 | 11:31 AM
Bandit5's Avatar
(Drive teeth X Axle ratio X Tire RPM) / 1001 = driven teeth
In your case:
Take your tire diameter: 25.16" and use it to find your tire RPM, which is (20168) / (diameter).
and calculate your tire RPM: (20168) / (25.16) = 801.59
Now, for drive teeth, you have several different options: 15, 17, 18, 19, and 20. The driven teeth are: 18, 19, 20, 21, 22, 23, 24, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45.
You need to calculate the closest one to perfect, which results in guess and check.
The most common drive gear is 15, so start with that.
(15 X 2.73 X 801.59) / 1001 = 32.79
According to this, your most accurate driven gear is a 33 tooth, which looking at the chart, does not exist, and a 34 would be a bit more off than you like, so try again with a different drive gear.
(17 X 2.73 X 801.59) / 1001 = 37.16
This is closer, and you can get a 37 tooth driven gear, so it is looking good, but you still have more options, lets see if we can get even closer.
(18 X 2.73 X 801.59) / 1001 = 39.35
That is worse, try again.
(19 X 2.73 X 801.59) / 1001 = 41.54
That is not very good, one more time.
(20 X 2.73 X 801.59) / 1001 = 43.72
Ok for a 44 tooth gear, but not great.
After all these calculations, it seems your most accurate gears will be a 17 tooth drive gear with a 37 tooth driven gear.
You will also need a new sleeve.
Take these numbers down, and order them form GM:
#8640517 - 17 tooth drive gear
#1359271 - 37 tooth driven gear
#25512340 - correct sleeve (if needed - you might already have the right one )
Old Nov 7, 2003 | 05:20 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
my tire size will either be 275/40 R 17 or 315/35 R 17 but I don't know where to find the diameter in inches.
my rear end ratio will be 3.42
Also, where can I find the part numbers for the different speedo gears so I can order the set that I need?
Thanks a lot, the help is greatly appreciated.
Old Nov 8, 2003 | 10:54 PM
Bandit5's Avatar
The 275/40/17 tires are actuallyt he same exact diameter as the popular stock 245/50/16, so if you had those 16" tires and the same gear ration, no change is necessary. The tire RPM is 784.747 so you can make with the claculations if you want, but I am pretty sure the 15 tooth drive gear is the best for this situation... lemme sut run the quick numbers, you can do the rest of the math yourself if you want to try other drive gears.
(15 X 3.42 X 784.747) / 1001 = 40.22
So 15 tooth drive gear with a 40 tooth driven gear is most likely your best bet, but feel free to run all numbers until you find somethig else you like.
Thise site has all part numbers you will need. Make note of the sleeve required, plus it has all the same formulas I use: http://www.73-87.com/garage/
After looking over his formulas I spotted this: "40300/1001 = 40.26 or 41 teeth"
I would have chosen 40 tooth gear as it is closer to the actual speed... why he chose 41 instead, beats me.
Old Nov 9, 2003 | 10:12 PM
25THRSS's Avatar
What about us guys with electric speedos?
Old Nov 10, 2003 | 12:57 PM
Bandit5's Avatar
Considering my car is a '90, which has the same speedo as yours, the gearing is the same, allthough I think the actual parts and part numbers are different. Do the same calculations with the drive and driven gear teeth, then go to GM and tell them you need those gears for an electric speedometer. It wasn't much of a problem for me, I told them I wanted and they got it for me... they took their sweet time getting them to me, but they got there nonetheless.
Old Nov 10, 2003 | 07:37 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Thanks a bunch. The main reason I was asking is because I'm swapping in a rear with 3.42's as opposed to the 3.08's in there now so I wanted the speedo to be right. I'll go down to the dealer and let them know what gears I need for everything to be right. Thanks again.
camaro11j
Sep 19, 2018 08:49 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
GTAman
Aug 27, 2015 10:29 PM
crazynights
Aug 21, 2015 06:53 AM
