please help me i think i am geting screwd
Old Nov 4, 2003 | 06:01 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i have a 700 r4 in my 1988 tbi k2500. just over 2 years ago i got a new trans put in at the stealer. it startet so hunt real bad an dnot shift right then about a week ago i lost second gear. it tacks out first then gose strait to drive. if i am going 40-45 and manualy shift to 2nd there is no thing there. i can rev it to the point that i hit my rev limeter 5600. so i brought it in the othere day. they told me today that they where going to check the valve body an clean the pan. imo i think there full of it what do you guys think could be wrong with this thing.
Old Nov 4, 2003 | 11:36 PM
c4boom's Avatar
Engine: l98 and lo5
up date they said that there is a pin or some thing in the valve body that is sticking causing it to skip shift over second. any one know enough about 700 r4 s to say if this is or not.
Old Nov 5, 2003 | 07:32 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I'd love to help, but you know how those "stealership" employees are...
Old Nov 5, 2003 | 10:05 AM
ede's Avatar
ede
lol bernard i knew you and your kind couldn't be trusted
Old Nov 5, 2003 | 02:23 PM
c4boom's Avatar
Engine: l98 and lo5
hay i admit that just cuz some one works at a dealer dosnt make them bad. i just hate all the red tape that dealers through at you. like one of the shops up hear only gives there mechanics 1/2 time for warranty work
Old Nov 8, 2003 | 10:54 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Thats probably to enocourage them to do a good job and not screw anything up the first time. Even if you bring it in for warrenty (and they get piad only half time) they most likely arn't going to a lousy job because that just means you will be in again for more warrenty work and its even less money for them. I think if they are stealing from anyone there, its from the mechanics.
Old Nov 8, 2003 | 11:25 AM
joshwilson3's Avatar
Old Nov 8, 2003 | 12:02 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
GM will re-imburse the dealer most of the time. There are alot of reasons why they won't, and yes, the rate is much lower. On a Water Pump that Chiltons or Mitchells says it takes 3.0 hours, GM usually pays about 1.7-2.2 hours.
It sucks, but its gotta be done. Crap work is better than no work.
GM will also not pay for "related" or "repeat" failures. If a tech replaces a water pump for a coolant leak, and it comes back for the same coolant leak, GM will request the "failed" parts to be sent to the Warranty Parts Center and if it appears to be technician error, the claim will be kicked back, which puts the cost of the repair on the dealer. Some dealers will take the flagged hours back from the tech. So it behooves the tech to do it right the first time and move on.
P.S. its not just GM either, its ALL manufacturers. If you go to flatratetech.com, you'll see that some Ford techs are trying to get a class action law suite because of Ford's warranty times.
Old Nov 8, 2003 | 01:38 PM
Old Nov 9, 2003 | 01:09 AM
c4boom's Avatar
Engine: l98 and lo5
well up date they had to give me a new trans a band in the other one broke in half and messed up the case. on top of that i looked at my slip and they clamed the same amount of time as i it took the first time. so it lookes like to be the dealer is screwing some one. i talked to the tech and he said he only got 2.5 hours for it. i was like thats cuz it is a 4wheel drive and you have to pull the plow frame to get the trans out thats a hour there alone.
87camaro kid
Car Audio
Dec 16, 2002 03:55 PM
87camaro kid
Oct 27, 2002 07:08 PM
87camaro kid
Jul 27, 2002 12:52 PM
91B4C jacob
Apr 19, 2001 10:57 AM
mirage2991
Apr 11, 2001 12:20 PM
