700 R4 messin up, go figure
Old Dec 8, 2003 | 01:20 AM
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
Tranny runs like a gem when cold, when car first starts up, but when gets warm, is terrible, shifts hard and at high rpms.....any suggestions??-- ps, fluids fine
Old Dec 8, 2003 | 01:23 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Get a trans fluid cooler, thats why it shift good when cold, cold fluid, warms up fluid gets hotter.
By terrible do you mean sluggish or dont shift.
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
it shifts real hard jerks the car
Old Dec 8, 2003 | 01:24 AM
Engine: 383, L69
when cold or hot
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
when hot, fluid coolers expensive?
Old Dec 8, 2003 | 01:26 AM
Engine: 383, L69
Fluid coolers are not that expensive, plus they add longevity to your transmission. Which would you rather pay for a cooler or a rebuild, see what im sayin.
shiftin hard when hot, have you tried adjusting your T.V cable
edit: https://www.thirdgen.org/newdesign/tech/detent.shtml
Old Dec 8, 2003 | 01:28 AM
Engine: 383, L69
You also might wanna PM Pro Built Automatics hes online at the moment, he knows a tremendous amount bout the 700R4
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
i havent messed with that but read about it earlier, do you think that that could be it, trans cooler seems like a too simple fix...i guess i was expecting the worse--i need a new trans---i may go see about adjusting it now
Old Dec 8, 2003 | 01:30 AM
Engine: 383, L69
Yeah if that dont help it talk to Pro Built Automatics hes knows his stuff.
Kevin
Old Dec 8, 2003 | 01:32 AM
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
thnx
Old Dec 8, 2003 | 01:36 AM
Pro Built Automatics's Avatar
It depends on what valve body modifcations have been, B&M for example can do this. Are the shifts at light throttle opening on the 1-2 shift hard? If the TV cable is set right (very little to no play at WOT) and there is not a valve body kit installed, and the shifts are late & hard when warm, then a stuck TV (throttle valve) can do this. The Trans-Go valve body kits can solve this with their "no-stick" throttle valve.
Old Dec 8, 2003 | 01:41 AM
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
there has been no mods to my knowledge but it does shift late and hard when warm...
Old Dec 8, 2003 | 09:24 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Great! I just bought a B&M kit. I take it you do not recomend it?
Can I make it work? or should I trash it? I can't return it, but have not installed it. I plan on using the RV/4X4 stage, not the street strip. Is there anything that I can do to the kit to make it livable?
Old Dec 9, 2003 | 11:34 AM
CamaroX84's Avatar
I've never heard anything good about the B&M shift kits.
Firebat
Nov 21, 2005 07:25 PM
CamaroX84
Nov 20, 2003 09:37 AM
1990GTA
Jun 30, 2003 12:42 AM
ctandc
Mar 27, 2003 10:11 AM
