whats my top speed with 4.10s witht the.....
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
what will my top speed be with 4.10's and my 700rd from a 89 formula with the 305 tbi engine.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are power limited and not gear limited for your case. Also if you have the still have the speed limiter, but recalibrated for those gears, you will still be at 115. If you do not change the speedo gears your top speed will be about 90.
i got 4.10s in my 85 ta with a 305 tpi, when i drag raced i trapped at 5600 or 5800 rpms and my trap speed was 87 mph all three runs, so about 90 is correct , my car will shift into 4th automatically but i have no clue how fast the car will go , i have the stupid 85 mph speedo, and the same size tires . i would also like to know what the top speed is.
Car: '90 RS
Engine: 377 LSX
Originally posted by 25THRSS
With 4.10's your top speed in third is gonna be a little more than 90 mph. If you are able to shift into OD at WOT you could possibly achieve over 130 mph.
Originally posted by ShiftyCapone
Gearing wise you are right, especially if he can wind out OD. But he is power limited with the LO3 and the motor will never be able to propell him at those speeds. Also, if he does not change his speedo gears or remove the limiter he will bounce off the limiter at around 90 or less beause the car thinks its going 115.
Car: '90 RS
Engine: 377 LSX
I agree about the speedo gears, but 130 isn't all that fast and given a large stretch of road he should be able to hit it with his mods. Back when I was completely stock I bounced off the 112 mph limiter a few times and I know I could have gone a lot faster.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I tried to see what the top speed of my car was. After around 120, I jammed the pedal all the way down to the floor and the front of the car lifted up and with no airdam and ~6 in. of ground clearence, all the air going underneath caused the front wheels to loose most of thier contact with the ground and I couldnt steer momentarily. Needless to say I wont be trying that again.
Car: '90 RS
Engine: 377 LSX
I think I'll just delete the limiter, hook up winaldl, and find out, lol.
Car: 88 Camaro SC
Engine: SFI'd 350
Its really more of an aerodynamic issue. My car sits pretty high and theres nothign to redirect air around the car rather then under it. Far too much air finds its way under the car causing a 'wing' effect. Feels great up to around 100 or so and after that it starts to get squirly.
Car: 88 Camaro SC
Engine: SFI'd 350
Big, fat 65 aspect ratio all season tires and unknown junkyard springs form the previous owner. I hate those all seasons. The sidewall has more compliance then the old yokohama's had. But unlike the yokohamas, I can actually drive in the snow.
Car: 84Z28
Engine: 12:1 355
Transmission: fairbanks turbo350
Re: whats my top speed with 4.10s witht the.....
1992 Trans Am
May 10, 2023 07:19 PM
