Replacing a Torque Converter
Old Jul 2, 2004 | 02:06 AM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Hey All.
I think my torque converter is in need of replacing. Whenever I am coming to a stop the car seems to drop RPM pretty low and then sputters to bring it back up to 600. Also when I put it in reverse and start applying the gas, the moment I let off on the gas and the car starts to slow down it tries to stall out on me again. I had it stall twice. Lately what I have been doign is I put it in reverse, get the speed I want and then drop it into neutral and then drive and go and when I am coming to a stop I drop it in neutral if I am gonna be sitting there long (red light). These things in my mind seem to be due to a ceasing converter.
SO!! I am thinking of getting a new torque converter but I have a few questions.
1) what is all involved in replacing the converter.
2) should I get a stock TC from GM or get an aftermarket one
3) if aftermarket, which brand?
Old Jul 2, 2004 | 02:27 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I don't know why you think it's the torque converter, based on your post I don't think it is. But, having killed 1 transmission and 2 torque converters, buy a good one. If you are planning lots of mods, lots of power get a Vigilante or a Yank. If you aren't planning on major power or don't want to spend that kind of money then I'd recommend a TCI, even though I just killed one.
Old Jul 2, 2004 | 06:15 AM
ThraxXx's Avatar
If its not the Torque Converter then what else could it be?
Old Jul 2, 2004 | 07:15 AM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
might be that the torque converter is not unlocking.
Old Jul 2, 2004 | 01:02 PM
ThraxXx's Avatar
Can that be fixed or does teh unit need to be replaced.
Old Jul 3, 2004 | 06:51 AM
Theres a switch in the trans. Gotta drop the pan
Old Jul 4, 2004 | 09:16 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
It also sounds to me that it is not unlocking.
Old Jul 5, 2004 | 08:51 PM
ThraxXx's Avatar
If I brought it to a transmission shop...do you think they would beable to figure it out?
Old Jul 7, 2004 | 01:18 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Correct me if I'm wrong, but if you disconnect the connector on the tranny the computer wont be able to ground it out and therefore never be able to lock the converter? If I'm understanding this correctly, that should prove whether or not it is due to the converter not unlocking.
Old Jul 7, 2004 | 07:34 PM
Unless the switch is stuck closed.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
gwade12
Aug 8, 2015 08:17 AM
