Trans Brake for 700R4
Old Nov 2, 2004 | 04:41 PM
Guest
Guest
Posts: n/a
anyone know where i can get a trans brake for a 700R4 Trans ??
everytime i look all i find is for a TH350 TH400 or power glide
Old Nov 2, 2004 | 04:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've seen one, but it was only available in a manual valvebody. Maybe it was from TCI, I don't remember.
Old Nov 2, 2004 | 04:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Didn't see anything on TCI's website. Art Carr has one, but it's on a reverse pattern valvebody.
Old Nov 2, 2004 | 06:50 PM
chris718's Avatar
we make one.
Old Nov 3, 2004 | 12:05 AM
Guest
Guest
Posts: n/a
Originally posted by chris718
we make one.
how much and is it a manual vavle body what
Old Nov 3, 2004 | 08:42 PM
chris718's Avatar
it is 599,automatic shift and contains boost valves ,accumulator springs,servo ,technical info.solenoid is internal and the reverse light power wire must be wired into the t brake solenoid so itll turn on the solenoid when in reverse.
Old Nov 3, 2004 | 09:18 PM
Guest
Guest
Posts: n/a
so i have to put it in reverse for the trans brake to work??? thats stupid
Old Nov 4, 2004 | 07:00 PM
chris718's Avatar
NO THE TRANSBRAKE ENERGIZES IN LO GEAR WITH THE BUTTON PUSHED.reverse uses the same solenoid therefore 12 volts must be supplied to the solenoid in order to engage the reverse input drum and initiate reverse movement.this is done to eliminate the complexity and length of the oil circuits if it applied the reverse clutch without the solenoid the integrity of the clutch packs would be at stake.this is very easily achieved by using the reverse light wire which sends current to the reverse lights to energize the solenoid when the selector is placed in reverse.it is very simple,certainly not stupid
Old Nov 5, 2004 | 03:17 AM
Guest
Guest
Posts: n/a
ok so the trans brake would be a vavle body with solenoids in it then right? because the only solenoid in my trans mission is for the TCC
what comes in the kit do you have a link to the part number on the web site?
Old Nov 5, 2004 | 03:33 AM
BaddAzzRS's Avatar
Car: 91 Camaro RS
Engine: SBC
damn .....700r4's have enough issues...whats breakage like with that...If I thought I could get away with it Id put one in my trans. I already have a totally built trans...what would I need just to add the brake?
Old Nov 5, 2004 | 05:03 AM
Guest
Guest
Posts: n/a
stock parts in a 700R4 with a transbrake do not mix my trans is beefed up with more then just a shiftkit
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
Leggman1
Aug 6, 2015 04:15 AM
