slight tranny problem
Old Nov 11, 2004 | 08:21 AM
ramair92rs's Avatar
Car: 92 rs
Transmission: AOD 700r4
well,the tranny only shifts into 2nd at 4500 rpm's then after
that it won't shift into a higher gear. any thaughts or suggestions would be appreciated.
Old Nov 11, 2004 | 12:04 PM
sprayedcam86's Avatar
Car: 86 camaro z28
Engine: wild 355 chevy sprayed with nos
have you changed the fluid.
Old Nov 11, 2004 | 01:31 PM
ramair92rs's Avatar
Car: 92 rs
yeah i did and it looked fine.
Old Nov 11, 2004 | 01:48 PM
Car: 86 camaro z28
sorry then i dont know im not really a tranny expert. i just new that was a good place to start.
Old Nov 11, 2004 | 01:50 PM
subliminal's Avatar
Try adjusting the TV Cable. If that dont work. Probably time for a rebuild
Old Nov 11, 2004 | 04:53 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
i recently had the same trouble and i installed a shift kit and had a good look around in there and did a good transmssion flush and it is better than ever now just a thought, i think mine was due to build up from being stored winters, just a guess though
Old Nov 11, 2004 | 08:35 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
among other small problems(reasons for late shift), probably a shot 3-4 clutch pack, which would prevent you from shifting out of 2nd. mine currently does the same thing.
definitely rebuild time.
Old Nov 14, 2004 | 12:30 PM
ramair92rs's Avatar
Car: 92 rs
well i appreciate all the input, i was hoping i wouldn't have to get a rebuild but it was bound to happen sooner or later i'm actually surprised it lasted this long. well thanks again, chris
Old Nov 14, 2004 | 08:11 PM
Pro Built Automatics's Avatar
Adding the modified Trans-go performace Shift kit, along with the Corvette servo & larger boost valves, will (if the 3-4 clutches are still in good shape) solve this in most cases. If i can be of help, let me know?
db057
Sep 4, 2015 07:57 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
