pro 5.0 help needed ASAP
Old Mar 12, 2005 | 01:39 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Okay well I got my pro 5.0, got the console off, took the stock shifter out and installed the new one no problem. Now that is in the shifter is like stuck. Its like I can push into 3rd gear and pull it back a little but not far enough to get it into neutral, it just has a half inch of play but I can't shift. I need to get this fixed because its holding up getting the rest of my interior in. Any help is appreciated.
Old Mar 12, 2005 | 02:38 PM
Car: 1990 Formula
nevermind, I got it now
Old Mar 12, 2005 | 11:39 PM
onebinky's Avatar
Whatd'ja do, forget to put the plastic cup on the bottom of the shifter back on?
Old Mar 13, 2005 | 12:28 PM
Car: 1990 Formula
Actually I had the adjustable stops pushed all the way up without noticing, felt pretty dumb for that one
Old Mar 13, 2005 | 05:14 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
theres a plastic cup on teh bottom of the shifter. oops i didnt put one on if i remeber correctly but it shifts well enuff but now my engine is ****ed.
Old Mar 13, 2005 | 06:11 PM
Car: 1990 Formula
I don't think there was a plastic cup either, the instruction make no mention of a plastic cup so I don't know, I'll see how it shifts once my car is running again.
Old Mar 19, 2005 | 10:22 AM
VILeninDM's Avatar
This is part of a rebuild kit from D&D:
I think the cup you guy are talking about is in top left corner. The shifter end that goes into a tranny has a ball on the end. That ball goes into this isolator cup which is pressed into the lever on the shift rail.
Old Mar 19, 2005 | 10:25 AM
VILeninDM's Avatar
Found a better picture of that cup in the tranny:
http://dxm004.homeip.net/gallery/vie...05&id=IMG_0772
IROCZ1989
Jan 24, 2016 03:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
