4th gear shift mod
Old May 23, 2005 | 12:00 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
4th gear shift mod
I've seen this before (maybe someone can poin me to the discussion/sticky) but what is the mod that needs to be done so that the my 700-R4 will shift into 4th gear w/o removing my foot from the pedal?....i will hopefully be putting in a shift kit this summer and maybe i can do that mod at the same time....thanks
Old May 23, 2005 | 07:07 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I think you need to purchase two valves. B&M makes a modified upshift valve, which does what you want; I think. There is also something else but I can't remember what it is.
I know they used to make a valve for B4C F-bodies to allow officers more throttle in 4th gear, but I'm not sure if that removed the 4-3 downshift at WOT.
Old May 24, 2005 | 05:39 PM
Car: 1988 SC Camaro
Engine: 305 TBI
ok...so there is no mod i can do myself when installing the Transgo Shift kit to get around adding another valve?...does anyone know where to buy the required part to do the mod? is it easy to do?
Old May 24, 2005 | 09:53 PM
Its been thrown back and forth, do a search of some old posts. At one point I remember someone stating that no valve could cause the transmission to shift into 4th gear at WOT. But there was a valve that could let you maintain about 90% throttle.
Its all in the old stuff and its been a long time since I've read any of it.
Old May 24, 2005 | 10:31 PM
Car: 1988 SC Camaro
Engine: 305 TBI
why do you suppose GM designed the car so that it wouldn't shift into 4th geat at WOT ?...it doesn't seem like a good design
Old May 25, 2005 | 12:06 AM
Two reasons I can think of off the top of my head..
One, the 700r4 doesn't deal very well with lots of torque in 4th gear very well. I'm assuming it was built that way to prevent people from burning up the transmission by going WOT in 4th gear.
Two? I think speed could have had something to do with the design. No 4th geat at WOT would keep the speeds down because you have to let off the gas.
Old May 25, 2005 | 01:47 AM
Pro Built Automatics's Avatar
The Corvette 700R4 has the WOT shift into 4th in most cases. You can do this by installing 2 allens screws into the 4-3 passages in the plunger sleeve. This will give you a WOT 4th in the majority of cases.
Old May 25, 2005 | 09:01 AM
Damn dana, since I don't have a schematic of the flow care to post one or a picture?
I'd do this tomorow if I knew exactly where to place the screws!
Old May 27, 2005 | 05:35 PM
Car: 1988 SC Camaro
Engine: 305 TBI
the LO3 has a lot of torque?
Old May 27, 2005 | 06:36 PM
Just a general quote. Thinking ported heads, 355sbc, Stealthram, or TPI, cammin, full exhaust.....
[channeling yoda]destroy the transmission will you.[/channeling yoda]
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
