shifting problem
Old Aug 26, 2005 | 01:37 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
shifting problem
I have a 700R4. After i rebuilt the engine ( i pulled the engine and tranny at the same time) I reconnected it all together and dropped everything back in. The only thing i touched of the tranny was i added a corvette servo. Anyway, now the tranny cant go into 1, 2, itll get into D, and will miss everything else (P, OD and N)...is there an adjustament for the cable on the shifter?...b/c ill move the shifter and watch it underneathe the car..and it wont move the lever on the tranny..
Old Aug 26, 2005 | 04:52 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
sounds like the shift cable housing came out of the bracket. i had the same thing happen to mine. i found the tabs on mine wouldn't stay in the bracket that bolts to the pan rail any longer. if you can, get one from the dealer. or at least not autozone. the one i got there wouldn't allow me to shift into 1st and 2nd. i have recently installed a B&M megashifter. i love it.
Old Aug 26, 2005 | 11:10 PM
Car: 1991 Z28
Engine: SBC
can you dumb that down a bit and give some locations lol....sorry im alittle new to transmissions..
Old Aug 26, 2005 | 11:22 PM
87zjeff's Avatar
sorry bout that. wasn't thinking.
your shift cable housing fits into a bracket at the transmission pan rail(driver's side). there are two tabs that hold the shift cable housing in this bracket. the tabs get worn and don't hold the cable in the bracket anymore. when this happens, the cable loses the tension requied to shift the transmission. when you pulled the transmission and engine, you had to either remove the bracket from the pan rail, or remove the shift cable housing from the bracket. if you removed te cable housing from the bracket, you may not have gotten it back in all the way. if you have any more questions, just ask.
Old Aug 27, 2005 | 09:25 AM
Car: 1991 Z28
Engine: SBC
Ok i get what you mean and what your talking about
Ok when i removed it from the car...i unbolted the entire assemlby from the pan ( i was gunna drop the pan on the tranny to drain any fluids that might be stuck in there)
so that cable was just hanging for like 5 months...with the weight of the bracket on it...maybe it did loosen it or hurt the tabs.
so if i go to get a new 1 what would i ask for?
Old Aug 27, 2005 | 11:04 AM
87zjeff's Avatar
just ask for a shift cable assembly for an automatic. you wil have to reuse your bracket if you get one from an autoparts store. i don't know about the dealer. a new assembly will come with a new boot where it passes into the the console. the dealer/auto parts store will ask you the typical year/make /model to get you the right assembly.
Old Aug 27, 2005 | 02:19 PM
Car: 1991 Z28
Engine: SBC
heres the problem....
Old Aug 27, 2005 | 02:46 PM
87zjeff's Avatar
yuk!!!! i didn't think about one doing that but it would have the same effect. the shift cable is a one piece assembly.
Old Aug 27, 2005 | 03:15 PM
Car: 1991 Z28
Engine: SBC
ok so just go order a new shift cable assembly?
any idea on the amount of $$?
ill just go to discount and get it..
Old Aug 27, 2005 | 03:17 PM
87zjeff's Avatar
http://store.yahoo.com/dpstore/akc7536.html
this page has one for about $40 bucks. part number included
Old Aug 27, 2005 | 04:15 PM
Car: 1991 Z28
Engine: SBC
ok i bought 1 but i cant get that damn shift cable off the bracket on the transmission...it doesnt look like there are any tabs to squeeze?
Old Aug 27, 2005 | 04:41 PM
87zjeff's Avatar
there are two tabs that look similar to the ones in your picture. i don't have a camera to take a pic of my old one. i think the tabs are more flat on the tranny end.
Old Aug 27, 2005 | 05:23 PM
Car: 1991 Z28
Engine: SBC
ok got it...now it just barely misses park...i can get the shift cable into the lever on the trans..when its in park
i can do 1st and 2nd though...and i bought it fron discount auto...so thats good
Old Aug 27, 2005 | 06:00 PM
87zjeff's Avatar
ok...kool. then it is just a matter of adjusting it now. loosen the bolt the not that holds the cable end onto the transmission shift lever and see if you can get it to move towards the rear of the car without moving the shift lever. then retighten the nut. this will help it engage in park better.
Old Aug 27, 2005 | 06:08 PM
Car: 1991 Z28
Engine: SBC
o my ****in ***....this is driving me crazy...it keeps getting all ****ed up..
i put the lever on the trans in park...then try to get the cable to the lever..doesnt work
im trying to mess with the bracket that holds the cable near the lever...
Old Aug 27, 2005 | 06:18 PM
87zjeff's Avatar
the cable will not fit too far back but if it is on to far forward it will cause problems. the bracket should be attatched to the pan in the 2nd and 3rd bolt holes from the rear(3rd and 4th from the front) on the drivers side.
Old Aug 27, 2005 | 07:37 PM
Car: 1991 Z28
Engine: SBC
the bracket on the pan is on the 2nd and 3rd from the front. I have 4 bolts on the pan on the drivers side..
Old Aug 27, 2005 | 10:43 PM
87zjeff's Avatar
i was also counting the bolt hole on the rear corner. if you are not counting this one, then you need to move your cable bracket back one hole. the front of the bracket should be on the 3rd bolt hole from the front.
Old Aug 27, 2005 | 11:26 PM
Car: 1991 Z28
Engine: SBC
oo....oops...but idk how thats going to help....im short already getting it into park...but o well, ill give it a shot tomorrow...thanks man i really appreciate everything
...ill post tomorrow on how it goes, thanks
Old Aug 28, 2005 | 08:56 AM
Car: 1991 Z28
Engine: SBC
i dont think thats right....the cable wont even reach the lever now...even if i put the lever in "1"
Old Aug 28, 2005 | 11:10 AM
Car: 1991 Z28
Engine: SBC
hey i got ur message...i went to central auto parts(they are amazing) and got a new shift cable...first time it worked ...however the cable is on a really tight angle though and that rubber groumet...wtf is that?...it doesnt even stay that well..at all... ill take a picture and post it up soon
Old Aug 28, 2005 | 11:19 AM
87zjeff's Avatar
rubber boot
yeah, that boot is a pain in the butt. all it does is keep the shift cable from rubbing the metal of the tunnel. i'm going to play with my own ride so i will check back later. btw, i didn't get the boot in mine all the way either.
Old Aug 28, 2005 | 03:12 PM
Car: 1991 Z28
Engine: SBC
Hows this look...it just looks like the cable is on such an angle as it goes to the shift lever...but hell..it works...no problems so i guess its the right way then?
Old Aug 28, 2005 | 03:16 PM
87zjeff's Avatar
hey bud, it looks just like mine did when it was factory. that was why i got confused about the bracket placement. i'm using B&M megashifter now and it uses the two holes i originally told you to use. yeah, big brain fart. i'm glad you got it taken care of. i'll catch ya later.
Old Aug 28, 2005 | 04:09 PM
Car: 1991 Z28
Engine: SBC
iight man thanks for all the help...im gunna get me a b&m soon heh
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
