BW M39 T5 speedo gears for 3:73!?!?!
Old Sep 4, 2005 | 09:18 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Hey there. I posted this a while back, perhaps in another forum. I have an '88 IROC with a Borg Warner M-39 T5 manual transmission and 3.08 stock gears. I'm upgrading to 3:73s and I can not find new speedo gears.
According to the local dealer, to get my speedometer correct, I need to change both the drive and the driven gear.
Can anyone point me in the right direction? I've tried several websites and even called a place or two. Tons of gears avaliable for the 700R4.., practically none for the T5. HELP!
Old Sep 4, 2005 | 09:52 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
What drive gear do you have? I found out what drive gear I had and used this calculator to find what driven gear I needed. http://www.tciauto.com/tech_info/speedo_gears.htm
Then I went to the dealer and ordered the closest one.
Old Sep 4, 2005 | 10:23 PM
Brisk's Avatar
I don't recall off hand what drive gear I have... but he looked it up for what I have and what I need. To get the proper ratio I need I require a new drive and driven gear, both of which are out of stock and unavaliable to order (discontinued). Therefore I'm SOL at the dealer...
Old Sep 4, 2005 | 10:42 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
When I called the dealer I was told what I needed was discontinued. When I went in the next day to get the sleeve and O ring, a different guy said he could get it just fine. Might try again and talk to someone else. If that doesn't work you can try TCI. I've been told they have everything, including T-5 speedo gears. I didn't check because I got mine from the dealer. Somewhere else you might try is Whatever It Takes.
1-800-940-0197
Old Sep 5, 2005 | 02:22 AM
Brisk's Avatar
Is that the number for TCI? also.. what is TCI? Thanks!
Old Sep 5, 2005 | 09:34 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
http://www.tciauto.com/tci.htm
Old Sep 5, 2005 | 12:58 PM
Brisk's Avatar
thanks!
Old Sep 8, 2005 | 03:53 PM
Brisk's Avatar
so.. TCI only does autos... unfortunatly they were of no help what so ever..
but I found these guys; http://moderndriveline.com/index.htm
and hopefully they'll be able to help. I talked to one guy and he took down all my information and he's going to find out what they have in stock and call me back.
Old Sep 8, 2005 | 04:20 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Cool, if you read my post I may need their help too.
Old Sep 8, 2005 | 05:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Search for jmd on this site. He'll fix you up with whatever you need (he found me the drive/driven gears for the 3.73's).
JamesC
Old Jul 3, 2006 | 04:08 PM
BADNBLK's Avatar
COTM Editor
Sorry to did this one up but it is exactly what I am trying to find.
Brisk - how did it turn out, did they help you?
Any return info on this would be greatly appreciated.
Old Jul 3, 2006 | 06:27 PM
Brisk's Avatar
yup, I've had no luck finding what I need...
Old Jul 3, 2006 | 07:22 PM
BADNBLK's Avatar
COTM Editor
That sucks. Let me know if you do, and I will do the same.
Later,
Brandon
z28wiz
Nov 13, 2015 07:32 PM
chazman
May 4, 2012 01:36 PM
TrueIroc
Mar 26, 2011 09:11 AM
KagA152
May 5, 2004 06:18 PM
