ES Tranny mount and pinion angle...
Old 10-09-2005, 02:04 PM
gruveb's Avatar
Car: 1989 IROC-1
On the 89 IROC, the tranny mount broke. Replacing it today and noticed that with the preload bar that is supplied with the mount, the new mount is about 1/4" or so taller than the stock mount.
Did the stock mount compress 1/4" or am I going to have some vibration problems?
Also, and this ticks me off, the cross member slot is too small for the bolt. Gotta drill or file it out.
Old 10-09-2005, 11:24 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
Re: ES Tranny mount and pinion angle...
yea you gotta **** with it to get it to bolt, but its much better
dont use that stupid plate that they give you, just the mount it self against the tranny that plate messes up the pinion angle and causes vibration
Old 10-09-2005, 11:36 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
another vote for the no-plate... works great without it.
Old 10-19-2005, 11:11 PM
gruveb's Avatar
Car: 1989 IROC-1
Well...I didn't take your advice, I put the stupid plate in and sure enough, I get some vibration at higher rpm.
Old 10-20-2005, 10:39 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
so did i when i first put mine in. take it back out, takes 10 minutes if you have 2 jacks.
Old 10-20-2005, 06:44 PM
gruveb's Avatar
Car: 1989 IROC-1
yeah, it's not even that hard (10 minutes) to remove. Took longer to change my clothes and wash my hands.
Old 10-20-2005, 08:08 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Hmm i cant even remember if i put the plate in or not i still got the original package ill have to check to see if i left it in there. I gots a high speed vibration...
Old 10-21-2005, 10:40 AM
thirdgen88's Avatar
Car: 1995 Corvette
If you followed the directions that came with it, you probably put it in... They say you have to... But, of course you do not..
F-body driver
03-06-2023 11:44 AM
Stryker412
09-07-2015 09:11 AM
apie2546
09-05-2015 07:40 PM
IROCZ1989
09-04-2015 11:54 AM
UltRoadWarrior9
09-02-2015 08:24 PM
Quick Reply: ES Tranny mount and pinion angle...
