Can I replace an 86 700r4 with a 90 700r4?
Old Oct 23, 2005 | 03:08 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
Well, can I?
Old Oct 23, 2005 | 03:17 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
thats a direct bolt in...both trans are exactly the same.
Old Oct 23, 2005 | 04:07 PM
ZZ4 86 Z28's Avatar
ok, cause i knew they changed something after 86. what was it by the way, it was like a revised something or other.
Old Oct 23, 2005 | 04:44 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The guts of the trans were revised, but the case is the exact same and will drop in no problem.
Old Oct 23, 2005 | 05:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What is the 90 one out of?
Old Oct 23, 2005 | 06:30 PM
ZZ4 86 Z28's Avatar
o same thing. 350 camaro.
Old Oct 24, 2005 | 01:48 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, pretty much a direct swap then. You'll need to move the speedometer gears and housing from the old one to the new one. The 90 is a better transmission than the 86.
Old Oct 24, 2005 | 05:38 AM
ZZ4 86 Z28's Avatar
cool, sounds like a go then. thanks a lot guys.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
jklein337
Sep 19, 2018 06:23 PM
Thornburg
Aug 25, 2015 01:46 AM
g.l.mos
Aug 22, 2015 12:02 AM
Leggman1
Aug 6, 2015 04:15 AM
