Govlock posi ??? any good??
Old Nov 5, 2005 | 02:00 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Anyone used one with good luck? How do they compare to an Eaton or Torsen?
Old Nov 9, 2005 | 09:27 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
they blow up.
Old Nov 9, 2005 | 09:31 PM
Dialed_In's Avatar
I had never heard of them until I came across them all over ebay. Figured they were junk. I was just wondering about them since I had never heard anything good or bad.
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Holy shizz, what kind of numbers were you pushing through it when it blew?
Old Nov 9, 2005 | 10:02 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
wasen't gov lock the stock units
Old Nov 10, 2005 | 12:12 AM
jmd's Avatar
jmd
Usually not in cars, though there may be exceptions. Usually they were a truck item.
Old Nov 10, 2005 | 08:56 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Trucks, yes I have one in my 95 s10. Low mileage unit or it would be gone. I paid a lot of $$$ for it when I ordered the truck not knowing I was getting a gov-loc. I assumed being familiar with Third gens and with the s10 rearend identical I was getting an Auburn differential or something similiar. Not one of GM's better ideas.
Old Nov 10, 2005 | 09:53 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
All the later (95 or so) GM G80 (posi) units were gov lock. Since there are few rear drive car anymore, most were found in trucks.
Old Nov 10, 2005 | 09:56 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
will work "fine" for regular everday driving but forget about standing on it at the track especially with drag radials or slicks.
Old Nov 10, 2005 | 10:33 AM
They are trash. They do not survive on pavement. Just go browse the S truck forums, look how many people grenade them with 6-cyls.
What they do, is act like a regular open diff, until the RPM difference between the axles exceeds approximately 150 RPM; at which point they lock up suddenly. In other words, you have NO POSI ACTION WHATSOEVER at launch; and no way to know when it's going to suddenly cut in. Then if the car gets any traction, it grenades when it locks. Altogether unsuitable for high-performance use.
The thing about the 95-up F cars having the Gov-Lock is WRONG. The posi units in F car 10-bolts from about 85 to 97 were Auburn; then from 98 up, they were Zexel Torsens. The ONLY F cars that got Gov-Locks were in the early 80s; and most of those have long since failed.
Old Nov 10, 2005 | 10:46 AM
Ricktpi's Avatar
My bad. After a little more research it looks as only trucks had the gov locks. Sorry to offend you Sofa, with my hasty & ill conceived reply
Old Nov 10, 2005 | 11:06 AM
Thanks!!! although, the slip-up didn't "offend" me, as such; I'd be more concerned about somebody that didn't already know, getting into some kind of confusion while trying to buy or sell parts or something like that. Or, worse yet (horror of horrors!!) making a fool of themselves and countless others in a Friday-night McDonalds-parking-lot monkey-spanking situation, as has been described here by others. Now that would be just plain wrong.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
mcgarnicle
Aug 12, 2015 04:58 PM
