top speed
Old Nov 20, 2005 | 12:22 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
top speed
I have a 92 305 tbi rs, my buddy has a 86 305 tpi. He can get his car up to 140 mph without breaking yellow, mine yellow lines around 110. The cars came with the same rear gears, both automatics, is there maybe a different gear ratio in the trans?
Old Nov 20, 2005 | 12:25 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
trans had the same gears throughout the entire production AFAIK, uless he has a modded trans.
Check your RPO codes, It was probably either ordered with a different rear or someone has swapped the rear.
Edit:
Just though of it, but maybe your lockup isnt engaging and your buddys is...
Old Nov 20, 2005 | 01:24 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
The 92 RS has a governer on the top speed. Was because of the tires it came with origionally. They were not Z rated so GM had to protect their ***.
Old Nov 20, 2005 | 05:35 AM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Wide open throttle in the RS will not let the transmission shift into 4th gear. With a stock rear, 3rd should let you go way past 110. I've had mine up there on ocaccion but only after a different chip in the computer.
Old Nov 20, 2005 | 06:15 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Yea my car has that governor. How would I know if my tcc isnt locking? Can you feel it when it unlocks? Because sometimes when im driving around hilly areas, itll bog in OD, and ill drop it into D and it feels like it drops twice. I wonder if someone has put different gears in my car. This 4500rpm at 110 has to stop though. I drive it on the Autobahn and I really want to hammer it but I cant. I know I can disconnect the governor, but whats the point?
Old Nov 20, 2005 | 11:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There are several methods that will allow the trans to hold 4th at WOT. There is the b-body 3-4 upshift fix kit from GM. There is also a mod to the TV sleeve that will allow 4th to be held. Do a search here using some of the words as keywords. There is a bunch of info on this. And yes, I agree with you, not being able to hold 4th is putz.
I used the b-body fix kit which also includes a larger boost valve. Between that and the aluminum driveshaft, I really need to keep an eye on the speedo. . .
RBob.
Old Nov 22, 2005 | 09:36 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
is the top speed governor related to the trans at all? because im putting a 90 trans into my 86z...will my top speed be cut off?
Old Nov 22, 2005 | 10:08 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
top speed is not related to the governor in the tranny at all. it is all in the programming in the ecm.
sonnax and transgo both make kits that allow wot upshifts into 4th gear.
Old Nov 23, 2005 | 09:59 PM
gatekeeper_2117's Avatar
Car: 82 firebird trans am, and an 88 firebird formula
Engine: 2 305 v8s
Transmission: munci m 21, and a 5 speed
i have a 1988 pontiac firebird fornula, and a 1982 pontiac firebird trans am, and my trans am will run 120 with a 4 speed muncie, and my formula will run 120 in 4th gear, and ive gotten up to 135 in 5th at about about 3.2k rpm (i think), but i dont have the ***** to take it any further.
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
gta90
Sep 15, 2015 04:00 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
InfinityShade
Aug 22, 2015 08:00 PM
