Converter selection help please
Old Jan 31, 2006 | 09:01 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Probably going with a Vigilante or comparable quality. My motor specs on my web page as well:
406
240 240 hyd roller cam at .050
shift point 6000 rpm
reg ported AFR 190s
150 shot.
probably about 3550 race weight.
I would appreciate any input on stall speed and converter selection. Thanks!
Old Feb 1, 2006 | 09:34 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Hughes 3200 stall. Call them up and give them your specs and they will suggest the right STR for you. Around $450 and will be much better than a Vig.
Old Feb 2, 2006 | 02:48 AM
Pro Built Automatics's Avatar
I do not know much about Hughes TC's, but I have used the Vigilante for many years now with much success, and I would recommend them highly. Let me know if I can be of help?
Old Feb 2, 2006 | 07:34 AM
Car: 1991 Firebird
Engine: 427 LSX
Probuilt, could you recommend a stall speed? Thanks!
Old Feb 2, 2006 | 08:58 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
what transmission are you running? 700R4? TH350? Some friends and I are all having great results with a convertor made by a company called Torco. They sell under Art Carr's name but I think their convertors are a bit different and less expensive than actual Art Carr. I gotta 9.5" that stalls precisely where I wanted it to and is very solidly built it even drives down the road like a normal car... All for $350
Cheaper or just as cheap as off-the-shelf brands yet built way better.
Old Feb 2, 2006 | 09:32 AM
Car: 1991 Firebird
Engine: 427 LSX
Why does it matter the trans I am running?
I am thinking either a t400, 700r4 or a 2004r. Thanks for the input guys, keep it coming!
Old Feb 2, 2006 | 09:53 AM
Dialed_In's Avatar
Some comanies make great converters and parts for TH400's, but cant build a 700R4 to save their life. Thats why. Different companies use different parts. The lockup clutches in one guys converter may be thicker/wider than the next guys.
Old Feb 2, 2006 | 09:54 PM
Car: '89 IROC-Z
The reason I ask is because a TH350/400 convertor won't be capable with a 700R4 and vice versa... I dont believe the company I recommended makes a 700R4 convertor but if they do I'm sure its more than $350
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 2, 2015 09:12 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
