Whats the difference between these castings?
Old Mar 20, 2006 | 06:13 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Both are 10 bolts. I've never seen one look like the second one.
<img src="http://members.cisdi.com/~anesthes/rear/oldrear.jpg">
<img src="http://members.cisdi.com/~anesthes/rear/newrear.jpg">
Old Mar 20, 2006 | 12:42 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
c'mon mang..
Old Mar 20, 2006 | 03:38 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I don't know......my 10 bolt looks different than both of those. I guess I should say I have the 8.5" 10 bolt.
Old Mar 20, 2006 | 03:44 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Is one a Dana?
Old Mar 20, 2006 | 07:08 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by my3rdgen
Is one a Dana?
I dont think so.. It's a 10 bolt. Looks to be 7.5/7.6", or at least, 7.5/7.62 cover bolts on.
The carrier says "patent # blah blah, copyright 1987". It seems to be an auburn carrier. The gears say "11/41 GM7 3.73 (M)"..
The brakes are PBR, says "made in austrailia" on them, like on the 9 bolts. I tried using ebrake cables for a 9bolt, and they wont fit over the arm on the caliper. So I gotta figure out ebrake cables.. It's really a mystery rear end..
The housing itself has a GM stamp on the top, with a weird number I can't make out, but the bottom doesnt have any GM stamping like the other 10 bolts i've seen.
At first I thought it was a 4th gen housing, but it measures out 62" from flange to flange..
-- Joe
Old Mar 20, 2006 | 07:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those same PBR brakes were used on 10 bolts. The rear-end selection didn't change anything to do with the brakes.
Old Mar 20, 2006 | 08:22 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I know which leads me to believe its a 90-92 rear end, I'm just wondering why the casting is different than any 10 bolt I've ever seen..
It's kinda weird.
-- Joe
Old Apr 13, 2006 | 05:41 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
but gm didn't produce a camaro or firebird with 3.73 gears after 86 according to this web sites tech data section.
Old Apr 13, 2006 | 07:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just because GM didn't do it at the factory doesn't mean someone else didn't do it later.
Old Apr 13, 2006 | 07:35 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I don't see why anyone would use old stock rear end gears unless they were on a super small budget. I'm on a tight budget but the cheaping out on rear end gears just doesn't seem smart or safe. If you blow the rear end on the track, you put yourself in a bad position. I've heard of guys slamming into walls because of it. Unless you know were I can get brand new set of 3.73 ring and pinion gears form gm for less than a set of richmond gears.
Old Apr 26, 2006 | 11:04 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
It's kinda weird.
-- Joe
They had a casting change and went to 304 Chinesium.
Old Apr 26, 2006 | 11:11 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
GM had more then one source for castings and they came from two different foundries with some minor external pattern differences. Happens all the time with different sources. No big deal.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
6speedIROC
16
Mar 15, 2023 08:33 PM
BOOT77
Oct 17, 2015 12:09 PM
355tpipickup
Sep 13, 2015 11:35 PM
john204481
Sep 7, 2015 03:22 PM
