T5 with cable in a 91 camaro
Old May 9, 2006 | 10:53 AM
C6matt's Avatar
Car: 05 C6, 91 z28 Vert, 66 Mustang vert
Engine: Ls2, TPI 350, 289 4bbl
Transmission: T-56, T-5, C4
Axle/Gears: 3.42,3.08,3.73
I have a 91 camaro that has had a rebuilt T5 put into it when I got it...
I was underneathe the car antd it has a cable - no speed sensor! what can I do to make this speedo work again? thanks!
Old May 9, 2006 | 11:23 AM
Get the VSS from a car at the junkyard, and install it.
One little screw (10mm head) is all it takes.
Look for a similar car to yours, same motor and so forth; the odds of the VSS having the right gear already on it, are much improved that way.
Old May 9, 2006 | 11:28 AM
C6matt's Avatar
thanks a ton! would the dealer stock a vss?
Old May 9, 2006 | 11:53 AM
I have no clue (and wouldn't know about the dealer, either...). That's sure not where I'd go to get it, if I needed one.
Old May 9, 2006 | 12:02 PM
C6matt's Avatar
would a parts store have it...I greatly distrust junkyard electronics
Old May 9, 2006 | 12:03 PM
kaptinkafeen's Avatar
Yes - so do many GM/Delco parts dealers - but be prepared to be soaked for every $ you have..... Up here in Canada a new OEM VSS was $110.00 - and that was last year when I went throught this whole scenario as well. Head off to a wrecker, there are many cars with the correct VSS in them.
-Andrew
Old May 9, 2006 | 12:14 PM
Then buy 5 of them. Surely one will be good.
It'll still cost you less than a quarter as much as one at the dealer.
Old May 9, 2006 | 12:25 PM
C6matt's Avatar
would one out of an auto work?, 5 speeds are in short supply..
Old May 9, 2006 | 12:31 PM
Unfortunately no...
Very different.
Old May 9, 2006 | 03:27 PM
VSS part # 25071437
Start by locating cars that are TBI powered - GMC Chev trucks 1500's (89-92) or even caddie's - I was able to pillage 4 from this source. Look around the back side of the passange side dash area as a start to your hunt.... I was able to find a pile of them. VSS were used in TBI cars as they did not run the same ECM set up as TPI car's.
All the best finding them
-Andrew
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
