How do I determine what RPM stall my torque converter should have?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I have a 355 with this cam in it:
COMPETITION CAMS
-270H MAGNUM CAM SPECS-
Valve Adjustment: hydraulic
Gross valve lift: .470" intake/ exhaust with 1.5 to 1 rockers
Duration at .006" Tappet Lift: 270 degrees intake/ exhaust
Duration @ .050": 224 degrees intake/ exhaust
Lobe lift: .313" intake/ exhaust
open close
intake 29 BTDC 61 ABDC
exhaust 69 BBDC 21 ATDC
Lobe Separation Angle is 110 degrees with 106 degree intake centerline
STRAIGHT UP = 106 degrees; cam is ground 4 degrees advanced
Operating range 1800 to 5800 rpm
I'm not sure what else is needed. It's a stock 700R4, soon to have 3.45 gears.
COMPETITION CAMS
open close
Take it to the chassis dyno.
Whatever RPM the motor's peak torque occurs at, get a converter with a stall about 200 RPM below that, for optimum launch. That might be a bit excessive on the street though.
I'd guess you'll want something in the 3200 RPM range. Maybe as low as 2800 if it's a street driver most of the time.
Yup, pretty straightforward.
Just temper the "max effort" result from the chassis dyno approach, with however little common sense you can get away with for the street (if any).
Shift at the RPMs that when you hit the new gear, you're back at your peak torque RPM. Which should put you shifting at or just above the peak HP RPM. Don't wind it up any farther, you'll slow the car down. And of course, shift a little earlier, so that the RPM doesn't continue to buld up while the trans is deciding to do its thing.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
After wasting my time and money being too conservative years ago with a 2200 stall, and now running a 3500 stall, I wouldn't go below 2800 if I were you and keep the lockup also. Stay away from b&m convertors also.
Car: 91' Pontiac Firebird
Call Andre at Edge(www.edgeracingconverters.com ). He will tell you exactly what you need. He is one of the best converter guys on the planet Edge converters are also one of the best out there. Remember, with the possible exception of camshafts, "You get what you pay for" is more true with torque converters than any other performance part.
Originally Posted by firebirdjosh
Why's that?
Eric-86sc
Aug 24, 2015 09:01 PM
